Best paint to replicate bare metal/steel?
#1537077
11/19/13 10:13 PM
11/19/13 10:13 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Rustoleum use to make one that was virtually identical but they have changed their formula and the new one appears to be a metalic rather than metal colored.
Careful, your character's showing!
Re: Best paint to replicate bare metal/steel?
[Re: can.al]
#1537080
11/19/13 11:53 PM
11/19/13 11:53 PM
mopar346
I'm not convinced RPM is right for one that will be driven. I really don't have a reason, I just have concerns. I need to see how it stands up in use for awhile. A properly painted surface will hold up and can be cleaned regularly.
[Re: mopar346]
#1537081
11/20/13 01:49 AM
11/20/13 01:49 AM
Posts: 27,468 So Cal
autoxcuda
So Cal
Read here if you are considering the painted faux metal look:
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Buy some RPM and try some of the paint methods in the thread above and make a decision that works for you.
[Re: mopar346]
#1537083
11/20/13 10:31 AM
11/20/13 10:31 AM
mopar346
Good thread but being 7 years old I will have to see what is still available. Fortunately I did my arms several years ago when I could still get the Rustoleum. I used the Eastwood tint to duplicate the cosmoline, orange and gold if I remember correctly. I also use 6 different colors of cast to duplicate the variance in nature cast parts, that why no 2 parts that bolt together are the exact same shade.
[Re: YYZ]
#1537085
11/20/13 03:06 PM
11/20/13 03:06 PM
mopar346
Thank you, not familiar with that brand, who carries it? Rattle can or sprayable?
[Re: burdar]
#1537087
11/20/13 05:07 PM
11/20/13 05:07 PM
Posts: 1,552 Sweden
71redcuda
Sweden
Cleaned them very carefully so there is zero rust,then covered ALL in clear coat.Even inside the clamps..Dont mind the bolts..
Testing these to see how good they hold up against rust.. paint vs RPM.
[Re: 71redcuda]
#1537089
11/20/13 07:46 PM
11/20/13 07:46 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Been there, done that, even with top dollar clear automotive finishes.....It will rust eventually under the clear...sorry
I've had the best long term results in "clearing" raw steel for cars that will get driven, often, with this....
[Re: mopar346]
#1537091
11/21/13 02:27 AM
11/21/13 02:27 AM
Posts: 1,552 Sweden
71redcuda
Sweden
Time out, I was thinking the tie rod sleeves were black, at least on AARs. Am I wrong???
Most of them were natural steel and some tubes has a darker finish to them. A few were painted from factory i belive.
[Re: can.al]
#1537093
11/21/13 11:29 AM
11/21/13 11:29 AM
mopar346
Currently I have my sleeves semi-gloos black (sprayed) and my tie rods raw (cast). To my understanding this is correct, or I guess from what ya'll are saying is an acceptable version.
[Re: Stewpar]
#1537094
11/21/13 11:56 AM
11/21/13 11:56 AM
Posts: 232 Nebraska
Dodge-N-Shelby
Nebraska
I prefer Eastwood's paints. Detail Gray and Spray Gray, quality for sure.......
Looking at Eastwoods website, I see that they have clear powder coatings with different levels of gloss. I wonder if anyone has done their clear over bare metal? Seems like that would hold up better than spray...if you could get the correct look. I have one of the Eastwood powder coat kits but have never used clear, just colors.
[Re: DAYCLONA]
#1537095
11/21/13 02:50 PM
11/21/13 02:50 PM
Posts: 6,584 SE Pa.
LimeliteAero
SE Pa.
Hey Mike, Do you flatten the gloss on that? The can reads it to be glossy and Im afraid its going to be too shiney. Im looking to protect the front spring hangers which are raw steel and will be driving the car more than trailering so I want something on them.
[Re: YYZ]
#1537096
11/21/13 06:14 PM
11/21/13 06:14 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Seymour's stainless steel paint has a good color plus some rust inhibitors
The 'inhibitors' don't last...
If you use it, you'll have to swab with penetrating oil every once in a while...
Been there, done that...
