Stock E body Tire size #1534723
11/18/13 01:50 PM
11/18/13 01:50 PM
MD
Kevins493 Offline OP
MD
Sorry guys, can't find it via search and due to reasons outside my control, I can't wait until I get home to look harder.. What is the maximum section width and tire height you can run on a stock wheelwell '73 E body with the springs in the stock location? Looking to go to a bias ply DOT tire, something like a Hoosier 28x11.5-LT or 29x11.5-LT.
Re: Stock E body Tire size [Re: Kevins493] #1534724
11/18/13 02:02 PM
11/18/13 02:02 PM
Renton Washington
Triple Threat Offline
Renton Washington
Well first off drop the "LT" because that means Light Truck
I think you can fit a 29.5x11.5 QTP but I'm not 100%, might need to offset the springs for that.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Stock E body Tire size [Re: Triple Threat] #1534725
11/18/13 02:35 PM
11/18/13 02:35 PM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
My 70 Challenger cold take 275/60-15 tires on a 8" wide rim and 4,5" backspace on a original 8 3/4 axel !
Re: Stock E body Tire size [Re: Mopar Guy] #1534726
11/18/13 03:16 PM
11/18/13 03:16 PM
VA.
mosweethemi Offline
mosweethemi  Offline
VA.
Hey The last Challenger I did I put P275X60X15 on with a 15x8 Ralley wheels. Works great and looks great on the car. (A REAL MOPAR MAN )
Re: Stock E body Tire size [Re: Triple Threat] #1534727
11/18/13 06:18 PM
11/18/13 06:18 PM
MD
MD
Haha, here in MD they don't teach us to read real good in school.
Thanks y'all..it had 275/60 mickeys on it..since it got hit I'm going to a bias tire and (for the most part) taking it off the street. I may just end up getting the 29.5x11.5 and moving the springs in with offset hangers if it doesn't fit.
Re: Stock E body Tire size [Re: Kevins493] #1534728
11/18/13 06:51 PM
11/18/13 06:51 PM
GEORGIA
barracuda7199 Offline
GEORGIA
With doctor diffs kit and a b body rear end you can run a 10" wheel with 5.5" back spacing no problem! It's a bolt in too
Re: Stock E body Tire size [Re: barracuda7199] #1534729
11/19/13 03:02 PM
11/19/13 03:02 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I had this combo on my 70' Challenger with 295/50-15 on 8" Rallye's before I mini tubbed it into the frame rails. Now I can fit 315/60/15 Drag radials or a 29.5x10.5W on it.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Stock E body Tire size [Re: 6PKRTSE] #1534730
11/19/13 03:41 PM
11/19/13 03:41 PM
GEORGIA
GEORGIA
325-50 et street radial under my car now. Rolled fender lips required
Re: Stock E body Tire size [Re: Kevins493] #1534731
11/20/13 04:03 PM
11/20/13 04:03 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
On my '73 Challenger with stock 8-3/4", stock wheel wells, stock spring locations, I can fit a 10" rim with a 5.5" backspacing.
From the information you provided I would say you should be able to use the 28x 10.0, 10.5 or 11.0 (I didn't see a Hoosier 28x11.5). http://www.hoosiertire.com/specdrag.htm
I didn't see a 29x11.5 listed. However, from my experience a 29/9.0 or 29/10.0 should clear. Most likely anything greater than a 12.0 section width is likely to interfer especially with a taller tire.
Re: Stock E body Tire size [Re: cruzin] #1534732
11/21/13 01:56 AM
11/21/13 01:56 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Here is what I did. Just get the offset kit. It's worth it. And simple.
https://board.moparts.org/ubbthreads/showflat.php?Number=7729170
