Re: Stock E body Tire size
[Re: Kevins493]
#1534724
11/18/13 02:02 PM
11/18/13 02:02 PM
Triple Threat
Renton Washington
Well first off drop the "LT" because that means Light Truck I think you can fit a 29.5x11.5 QTP but I'm not 100%, might need to offset the springs for that.
[Re: Triple Threat]
#1534727
11/18/13 06:18 PM
11/18/13 06:18 PM
Posts: 2,379 MD
Kevins493
MD
Haha, here in MD they don't teach us to read real good in school.
Thanks y'all..it had 275/60 mickeys on it..since it got hit I'm going to a bias tire and (for the most part) taking it off the street. I may just end up getting the 29.5x11.5 and moving the springs in with offset hangers if it doesn't fit.
[Re: 6PKRTSE]
#1534730
11/19/13 03:41 PM
11/19/13 03:41 PM
Posts: 280 GEORGIA
barracuda7199
GEORGIA
With doctor diffs kit and a b body rear end you can run a 10" wheel with 5.5" back spacing no problem! It's a bolt in too
I had this combo on my 70' Challenger with 295/50-15 on 8" Rallye's before I mini tubbed it into the frame rails. Now I can fit 315/60/15 Drag radials or a 29.5x10.5W on it.
325-50 et street radial under my car now. Rolled fender lips required
[Re: Kevins493]
#1534731
11/20/13 04:03 PM
11/20/13 04:03 PM
Posts: 1,142 Tucson, AZ
cruzin
Tucson, AZ
On my '73 Challenger with stock 8-3/4", stock wheel wells, stock spring locations, I can fit a 10" rim with a 5.5" backspacing. From the information you provided I would say you should be able to use the 28x 10.0, 10.5 or 11.0 (I didn't see a Hoosier 28x11.5). http://www.hoosiertire.com/specdrag.htmI didn't see a 29x11.5 listed. However, from my experience a 29/9.0 or 29/10.0 should clear. Most likely anything greater than a 12.0 section width is likely to interfer especially with a taller tire.
