Re: 74 Challenger front chrome part over grill
[Re: Merlin45]
#1532516
11/12/13 08:32 AM
11/12/13 08:32 AM
Posts: 8,847 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
Yes its repoped we bought one for our 74 metro had/made it if i remember right
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: Merlin45]
#1532523
11/15/13 09:48 AM
11/15/13 09:48 AM
toplescuda
I Whine
I Whine
poplar bluff mo.
They come off and on pretty easy if you putting on.a new grille they just snap in place just mock it up you will see where the clips need to be (they slide along back side of the molding take your hand n bump them into place
pic with our newer trim
[Re: Merlin45]
#1532525
11/15/13 05:44 PM
11/15/13 05:44 PM
Posts: 4,323 St. Louis, Mo
318 Stroker
St. Louis, Mo
Thanks for the help. I'll be darn careful as I remove and install the new molding. If you want to see my Challenger go to: HnHRodShop.com
Just saw your Challenger, and as the owner of a 73 Challenger, yours is beautiful...
As for the molding, it's pretty simple to remove and re-install. I used a thin plastic prybar, with a little padding on the paint. Once you get one end off, it's easy to gently pop it off, one fastener at a time. You'll see how the fasteners attach, and they're easy to re-install on the new molding. You can slide the fasteners in the molding to get them to line up with the holes. It's a pretty easy job to do. Even I could figure it out...
[Re: Merlin45]
#1532528
11/16/13 02:17 PM
11/16/13 02:17 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
Yes there is a molding there if look close can see it on our challenger some day need to buy a new one as ours is all scratched up
[Re: burdar]
#1532531
11/16/13 10:27 PM
11/16/13 10:27 PM
Posts: 2,107 Third Stone from the Sun
Scotts72Rallye
The valance moulding is one you see missing so much on the 72-74 Challengers. IMHO the grill looks unfinished without it. If you find one on a donor car be careful removing it, very delicate in the center area. I found out the hard way! Scott
1972 Dodge Challenger Rallye UNDER CONSTRUCTION
