Side cover on 4 speed trans #1529746
11/07/13 10:11 AM
11/07/13 10:11 AM
Nashville, TN
MOPARMIKE69 Offline OP
Nashville, TN
Is there a trick to putting the cover back on a 4speed out of a 70 road runner.
I know about the shift forks and had no problem with them. However now I can't get it in reverse.
There has to some trick with the reverse. Checked the shop manual and I understand the concept.
One article I read on line says " with up ward pressure hold the cover and put it in reverse, then put the four corners bolts in" So how does the reverse mesh with the other shift assemblies?
Thanks for any help.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Side cover on 4 speed trans [Re: MOPARMIKE69] #1529747
11/07/13 10:46 AM
11/07/13 10:46 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The reverse lever is cast into the case, not the side cover so I don't see what reverse had to do with it other than maybe get it out of the way. Anyhow, try turning either the input or output while trying to put it in reverse - chance are its just hitting a tooth which won't allow it to engage.
Re: Side cover on 4 speed trans [Re: Stanton] #1529748
11/07/13 12:05 PM
11/07/13 12:05 PM
Nashville, TN
Nashville, TN
Yes it isn't part of the cover but the reverse lever interacts with the rear shift lever on the cover.
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
Re: Side cover on 4 speed trans [Re: MOPARMIKE69] #1529749
11/07/13 12:33 PM
11/07/13 12:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Typical problem, loosen the bolts, put it in reverse then slightly pry up on the cover from the bottom while retightening the bolts. There is an interlock of sorts built into the trans between reverse and the 1/2 lever to keep the trans from going into reverse if the 1-2 in not in the neutral position.
Re: Side cover on 4 speed trans [Re: JohnRR] #1529750
11/07/13 12:40 PM
11/07/13 12:40 PM
Nashville, TN
Nashville, TN
Thanks John it makes sense now.
69 Road Runner vert
69 GTX hard top
70 Hemi Cuda vert
