Is there a trick to putting the cover back on a 4speed out of a 70 road runner.
I know about the shift forks and had no problem with them. However now I can't get it in reverse.
There has to some trick with the reverse. Checked the shop manual and I understand the concept.
One article I read on line says " with up ward pressure hold the cover and put it in reverse, then put the four corners bolts in" So how does the reverse mesh with the other shift assemblies?
Thanks for any help.
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
