Side cover on 4 speed trans
#1529746
11/07/13 10:11 AM
11/07/13 10:11 AM
Posts: 2,636 Nashville, TN
MOPARMIKE69
Nashville, TN
Is there a trick to putting the cover back on a 4speed out of a 70 road runner. I know about the shift forks and had no problem with them. However now I can't get it in reverse. There has to some trick with the reverse. Checked the shop manual and I understand the concept. One article I read on line says " with up ward pressure hold the cover and put it in reverse, then put the four corners bolts in" So how does the reverse mesh with the other shift assemblies? Thanks for any help.
69 Road Runner vert 69 GTX hard top 70 Road Runner 4 speed 70 Hemi Cuda vert
Re: Side cover on 4 speed trans
[Re: Stanton]
#1529748
11/07/13 12:05 PM
11/07/13 12:05 PM
MOPARMIKE69
Nashville, TN
Yes it isn't part of the cover but the reverse lever interacts with the rear shift lever on the cover.
