Fresh rebuilt 727 trans - why does it vibrate?
#1529240
11/05/13 10:27 PM
11/05/13 10:27 PM
Posts: 7,538 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
Guys / gals,
What the most likely place to start looking for a vibration from my freshly rebuilt 727?
The shop is taking it back for a look-see tomorrow AM and I'm interested in the "talking points". I figure most likely a poorly balanced converter? Otherwise I figure there ain't much that gets balanced.
BACKGROUND: Local shop, very reputable and reliable Mopar-lovers. I gave them my car with 727 for a rebuild, new converter, seals, bands, etc. They pulled the tranny, opened it up, found busted flanges in the case at the pump. I went over there and they showed me everything. So we bought a used 727 and swapped all my stuff into the unbroken case.
The 'new' tranny shifts and drives 200% better than my old one - nice and tight - except it vibrates in "waves" when accelerating - around 25mph, 45mph and not so much above that. How much does it vibrate? - Enough to make the car feel "rough".
It doesn't do it off-throttle. I feel it in my butt. Plus a little vibration in the steering wheel. I think it's the tranny and the shake is transmitted to the chassis at the mounts.
Opinions?
Thanks! - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Fresh rebuilt 727 trans - why does it vibrate?
[Re: 67SATisfaction]
#1529241
11/05/13 10:29 PM
11/05/13 10:29 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Unbolt the rear of the driveshaft and rotate it 180 degrees, bolt it back in and test. Sometimes it is as simple as that.
Does it vibrate at speed in neutral?
[Re: Supercuda]
#1529242
11/05/13 10:50 PM
11/05/13 10:50 PM
67SATisfaction
Albany, NY
Thanks - I'll test the vibration in N at road speed. I don't know if they disconnected the rear of the shaft, but trying to rotate it 180 is reasonable (and easy). Because the "feel" of the vibration is kinda like that. Not as strong as an unbalanced tire.
I'll go try that right now. - Art
[Re: 80fbody]
#1529246
11/06/13 12:09 AM
11/06/13 12:09 AM
67SATisfaction
Albany, NY
Thanks 80fbody - It's a '67 Satellite with original 383 2bbl engine. I don't know which it has, but I'll find out online.
And - I eliminated the yoke/driveshaft/u-joints as possible culprits:
Just sitting in the driveway with the engine running, in Park or Neutral, I can bring on the vibration just by throttling up to the "right" RPM**.
It's going back to the shop tomorrow and I'll have them check the part number.
I think we're done here. - Art
**PS - At roadspeed, putting it in Neutral and dropping the engine down to idle, the vibration goes away completely.
#1529248
11/06/13 12:37 AM
11/06/13 12:37 AM
Posts: 1,760 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
HOLY SMOKES!!!
This is exactly the problem I have...and this is on a freshly rebuilt 360 motor, factory crank, offset weight crank damper, B&M offset flexplate and neutrally blanced converter. Brand new driveshaft, new U-joints, new Yokes (trans and rear end, that's billet piece). The motor was balanced at a machine shop.
I ruled out all drivetrain motion culprits since the 'wave' goes in Neutral/Park as the car sits and the RPMs are raised.
Best I can tell is that the shop either completely screwed up the balance job, or the converter itself is off-balance. The unknown in my case is whether having the converer sitting in a box for several years (like 10 actually...lol) while I worked on the car has caused some kind of damage to it.
[Re: mopar_man]
#1529250
11/06/13 09:59 AM
11/06/13 09:59 AM
Posts: 75,017 U.S.S.A.
JohnRR
U.S.S.A.
I'm saying ....wrong converter.
I'd lean toward this , it's an engine imbalance if it does it sitting stopped , it's not inside the trans .
[Re: RapidRobert]
#1529252
11/06/13 10:53 AM
11/06/13 10:53 AM
Diplomat360
Windsor, ON, Canada
True...not sure about OP's details, but in my case the vibration comes and goes in 'waves'...so at any particular RPM, it's this wave like pattern that is felt...at some RPMs the pulse is higher in amplitude, ie it is stronger, at other RPMs it's much less intense.
[Re: JohnRR]
#1529255
11/06/13 11:59 AM
11/06/13 11:59 AM
RapidRobert
You're too sharp for me bro , I gotta have the coffee 1st
[Re: RapidRobert]
#1529257
11/07/13 05:43 PM
11/07/13 05:43 PM
67SATisfaction
Albany, NY
Yep - the new torque converter was not balanced correctly from the M'fr. The shop owns up to it and says it happens about 1% of the time.
For diagnosis - with the car parked and the engine running in Park or Neutral the only parts that rotate are the (pistons, crank, cam(s), flex plate and t.converter. I could find the shake at certain harmonic RPM's. An added diagnosis was to drive the car down a moderate hill, find the vibration, then shift to Neutral and turn the engine off - and the shake disappears, which eliminates yoke/driveshaft/ujoint imbalance.
The engine is not a factor because it was smooth before the tranny rebuild.
The shop mechanic sat in the car, revved it a couple times in Park and knew it was the TC.
According to the mechanic, there are two types of TC's, one for 360 and one for the 383/440 BB's. They ordered the correct part number, but they simply got an incorrectly balanced TC right out of the box.
They'll get me in the shop next week. - Art
[Re: Supercuda]
#1529259
11/07/13 06:56 PM
11/07/13 06:56 PM
Posts: 1,606 westerly, ri. usa
440lebaron
westerly, ri. usa
if your old convertor had no wights and new one does you can just knock them off
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
