Fresh rebuilt 727 trans - why does it vibrate? #1529240
11/05/13 10:27 PM
11/05/13 10:27 PM
Albany, NY
67SATisfaction Offline OP
The member whose name is actually Art
Albany, NY
Guys / gals,
What the most likely place to start looking for a vibration from my freshly rebuilt 727?
The shop is taking it back for a look-see tomorrow AM and I'm interested in the "talking points". I figure most likely a poorly balanced converter? Otherwise I figure there ain't much that gets balanced.
BACKGROUND:
Local shop, very reputable and reliable Mopar-lovers. I gave them my car with 727 for a rebuild, new converter, seals, bands, etc. They pulled the tranny, opened it up, found busted flanges in the case at the pump. I went over there and they showed me everything. So we bought a used 727 and swapped all my stuff into the unbroken case.
The 'new' tranny shifts and drives 200% better than my old one - nice and tight - except it vibrates in "waves" when accelerating - around 25mph, 45mph and not so much above that. How much does it vibrate? - Enough to make the car feel "rough".
It doesn't do it off-throttle. I feel it in my butt. Plus a little vibration in the steering wheel. I think it's the tranny and the shake is transmitted to the chassis at the mounts.
Opinions?
Thanks!
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Fresh rebuilt 727 trans - why does it vibrate? [Re: 67SATisfaction] #1529241
11/05/13 10:29 PM
11/05/13 10:29 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Unbolt the rear of the driveshaft and rotate it 180 degrees, bolt it back in and test. Sometimes it is as simple as that.
Does it vibrate at speed in neutral?
Don't be the exception.
Re: Fresh rebuilt 727 trans - why does it vibrate? [Re: Supercuda] #1529242
11/05/13 10:50 PM
11/05/13 10:50 PM
Albany, NY
Albany, NY
Thanks - I'll test the vibration in N at road speed. I don't know if they disconnected the rear of the shaft, but trying to rotate it 180 is reasonable (and easy). Because the "feel" of the vibration is kinda like that. Not as strong as an unbalanced tire.
I'll go try that right now.
- Art
Re: Fresh rebuilt 727 trans - why does it vibrate? [Re: 67SATisfaction] #1529243
11/05/13 10:52 PM
11/05/13 10:52 PM
Opinions
yoke/driveshaft/ujoints/too much driveshaft end play, not the trans (other than the rear ext housing bushing)
Re: Fresh rebuilt 727 trans - why does it vibrate? [Re: 67SATisfaction] #1529244
11/05/13 11:38 PM
11/05/13 11:38 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
I'd also check the converter part number to confirm it's the right balance as in internal balance forged motor or cast external. Not sure whether you're running a SB or BB from the post.
Re: Fresh rebuilt 727 trans - why does it vibrate? [Re: 80fbody] #1529245
11/06/13 12:06 AM
11/06/13 12:06 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Check the tail shaft bushing. If the yoke is sloppy in the bushing it will go into convulsions like that.
Kevin
Re: Fresh rebuilt 727 trans - why does it vibrate? [Re: 80fbody] #1529246
11/06/13 12:09 AM
11/06/13 12:09 AM
Albany, NY
Albany, NY
Thanks 80fbody - It's a '67 Satellite with original 383 2bbl engine. I don't know which it has, but I'll find out online.
And - I eliminated the yoke/driveshaft/u-joints as possible culprits:
Just sitting in the driveway with the engine running, in Park or Neutral, I can bring on the vibration just by throttling up to the "right" RPM**.
It's going back to the shop tomorrow and I'll have them check the part number.
I think we're done here.
- Art
**PS - At roadspeed, putting it in Neutral and dropping the engine down to idle, the vibration goes away completely.
Re: Fresh rebuilt 727 trans - why does it vibrate? [Re: 67SATisfaction] #1529247
11/06/13 12:17 AM
11/06/13 12:17 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
They didn't put in a cast crank converter by mistake did they? You can see the balance weight or the lack of thru the inspection cover when you turn the engine over.
Kevin
Re: Fresh rebuilt 727 trans - why does it vibrate? [Re: 67SATisfaction] #1529248
11/06/13 12:37 AM
11/06/13 12:37 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
HOLY SMOKES!!!
This is exactly the problem I have...and this is on a freshly rebuilt 360 motor, factory crank, offset weight crank damper, B&M offset flexplate and neutrally blanced converter. Brand new driveshaft, new U-joints, new Yokes (trans and rear end, that's billet piece). The motor was balanced at a machine shop.
I ruled out all drivetrain motion culprits since the 'wave' goes in Neutral/Park as the car sits and the RPMs are raised.
Best I can tell is that the shop either completely screwed up the balance job, or the converter itself is off-balance. The unknown in my case is whether having the converer sitting in a box for several years (like 10 actually...lol) while I worked on the car has caused some kind of damage to it.
Re: Fresh rebuilt 727 trans - why does it vibrate? [Re: Diplomat360] #1529249
11/06/13 08:50 AM
11/06/13 08:50 AM
Newfoundland
mopar_man Offline
mopar_man  Offline
Newfoundland
I'm saying ....wrong converter.
Re: Fresh rebuilt 727 trans - why does it vibrate? [Re: mopar_man] #1529250
11/06/13 09:59 AM
11/06/13 09:59 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'd lean toward this , it's an engine imbalance if it does it sitting stopped , it's not inside the trans .
Re: Fresh rebuilt 727 trans - why does it vibrate? [Re: JohnRR] #1529251
11/06/13 10:36 AM
11/06/13 10:36 AM
I would think that if it was a TC/eng balance issue that once the RPM got high enough for the imbalance amount to be enough for it to be felt that that amount of vibration would either stay the same or get more pronounced as the RPM increased rather than come and go as the RPM increases. It wouldn't be going back into balance as the RPM's went up
Re: Fresh rebuilt 727 trans - why does it vibrate? [Re: RapidRobert] #1529252
11/06/13 10:53 AM
11/06/13 10:53 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
True...not sure about OP's details, but in my case the vibration comes and goes in 'waves'...so at any particular RPM, it's this wave like pattern that is felt...at some RPMs the pulse is higher in amplitude, ie it is stronger, at other RPMs it's much less intense.
Re: Fresh rebuilt 727 trans - why does it vibrate? [Re: RapidRobert] #1529253
11/06/13 11:26 AM
11/06/13 11:26 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
With the trans in park and neutral there isn't much of anything inside the trans that is spinning , the input shaft , the rear clutch retainer and the maybe the front clutch via parasitic drag, which would spin the sun shell, everything that is splined to the output shaft is not moving if the car is not moving .
Anything bolted to the the crankshaft is spinning when the engine is running and it becomes part of the engine imbalance equation.
Re: Fresh rebuilt 727 trans - why does it vibrate? [Re: JohnRR] #1529254
11/06/13 11:51 AM
11/06/13 11:51 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Someone said something naughty ???
Re: Fresh rebuilt 727 trans - why does it vibrate? [Re: JohnRR] #1529255
11/06/13 11:59 AM
11/06/13 11:59 AM
You're too sharp for me bro , I gotta have the coffee 1st
Re: Fresh rebuilt 727 trans - why does it vibrate? [Re: JohnRR] #1529256
11/06/13 12:33 PM
11/06/13 12:33 PM
everything that is splined to the output shaft is not moving if the car is not moving.
Yes that would take everything from the problematic ext housing bushing rearward out of the picture if it is still vibrating/shaking in park/neutral. Holler with any updates
Re: Fresh rebuilt 727 trans - why does it vibrate? [Re: RapidRobert] #1529257
11/07/13 05:43 PM
11/07/13 05:43 PM
Albany, NY
Albany, NY
Yep - the new torque converter was not balanced correctly from the M'fr. The shop owns up to it and says it happens about 1% of the time.
For diagnosis - with the car parked and the engine running in Park or Neutral the only parts that rotate are the (pistons, crank, cam(s), flex plate and t.converter. I could find the shake at certain harmonic RPM's. An added diagnosis was to drive the car down a moderate hill, find the vibration, then shift to Neutral and turn the engine off - and the shake disappears, which eliminates yoke/driveshaft/ujoint imbalance.
The engine is not a factor because it was smooth before the tranny rebuild.
The shop mechanic sat in the car, revved it a couple times in Park and knew it was the TC.
According to the mechanic, there are two types of TC's, one for 360 and one for the 383/440 BB's. They ordered the correct part number, but they simply got an incorrectly balanced TC right out of the box.
They'll get me in the shop next week.
- Art
Re: Fresh rebuilt 727 trans - why does it vibrate? [Re: 67SATisfaction] #1529258
11/07/13 06:52 PM
11/07/13 06:52 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I guess the shop doesn't dyno their transmissions after a rebuild? If they do, they should have found the vibration then.
Re: Fresh rebuilt 727 trans - why does it vibrate? [Re: Supercuda] #1529259
11/07/13 06:56 PM
11/07/13 06:56 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
if your old convertor had no wights and new one does you can just knock them off
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
