Smallest battery you have used? #1527231
11/01/13 11:44 PM
11/01/13 11:44 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Smallest mainly meaning lightest. I am disregarding the CF/Lithium stuff, because of +$1K cost and fear of fire Since handling is all about weight, and many are concerned with under 1 lb gains, seems like losing 20lbs? in a battery would be a no brainer. Additionally since CCA rating is somewhat related to ultimate battery weight, the real question is what is the lowest CCA rating you have felt comfortable with, in getting your car started when in good running form? I could have asked this in race section, but 1/4 mile is all about rear bumper mounted truck batteries or something.
Re: Smallest battery you have used? [Re: jcc] #1527232
11/01/13 11:55 PM
11/01/13 11:55 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I use a CAT battery and have it in the trunk for the counter balance effect. Braille makes super light weight batteries IIRC. Batteries are not somewhere I would skimp on as far as output and reliability go. My car has a stereo too lol.
Mopar to the bone!!!
Re: Smallest battery you have used? [Re: 72Swinger] #1527233
11/02/13 12:44 AM
11/02/13 12:44 AM
USA
Consulier Offline
Consulier  Offline
USA
Taxi has a 17lb Braille in the stock tray. I ran the entire 2 days of the Tire Rack test with no alternator. Just 5 minute charges between runs and tire changes. Never missed a beat and performed flawlessly.
I actually ran Motorstate the same way. Guess I'll get around to swapping alternators this winter.
Re: Smallest battery you have used? [Re: Consulier] #1527234
11/02/13 12:59 AM
11/02/13 12:59 AM
Battle Ground, Washington
Rapom65 Offline
Rapom65  Offline
I've run a Dyna Bat dry cell battery, 13.5 lbs, from Davis Unified Ignitions (avail at Summit Racing) for over 5 years in my 318 65 Cuda. I let it sit in storage for 1 year and then two winters without charging and it is still working great after a good trickle charge. I really like it. Seems to have plenty of juice to crank over a V8.
Re: Smallest battery you have used? [Re: Rapom65] #1527235
11/02/13 02:28 AM
11/02/13 02:28 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I've seen $150 Lithium's that weight 2 lbs that I'm told will do fine in a car with 210 CCA
Can CCA in a Lithium battery be treated different than a old wet battery??
They do have 540 CCA lithiums for $308, but those are 4.96 lbs FATTY's.
Re: Smallest battery you have used? [Re: autoxcuda] #1527236
11/02/13 12:01 PM
11/02/13 12:01 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
I'd be fine fine I think with 540 CCA fatty at $308, is the chance of fire with lithium real or very remote?
Re: Smallest battery you have used? [Re: autoxcuda] #1527237
11/03/13 10:13 AM
11/03/13 10:13 AM
USA
Consulier Offline
Consulier  Offline
USA
What brand? Do you have a link?
Re: Smallest battery you have used? [Re: autoxcuda] #1527238
11/03/13 11:46 AM
11/03/13 11:46 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
I'd be in for some of those batteries. Got a link to where I can get em?
Re: Smallest battery you have used? [Re: Consulier] #1527239
11/03/13 12:20 PM
11/03/13 12:20 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
These are Lithium Motorcycle and ATV batteries. Same applications people were getting the dry cells from.
It seems these batteries are sold under various resellers "labels". I don't know the true manufacturer.
Phantom Battery
Shorai Battery
$169: 18 Ah, 270 CCA, L = 5.83”, W = 2.28”, H = 3.50”, 2.31 lbs: http://www.ebay.com/itm/APP18L1-BS12-12V...=p2054897.l4275
$199: 5.5 lbs 12V 21Ah 315CCA: http://www.ebay.com/itm/APP21L6-BS12-12V...=p2054897.l4275
http://www.amazon.com/Shorai-Lithium-Batt-18Ah-LFX18A1-BS12/dp/B007GR5DXE/ref=pd_sbs_auto_1
LFX36L3-BS12, $270, 5.5 pounds, 7.7 x 5.7 x 8 inches, 18AH, read review that it's listed at 520 CCA, other review tested it at 1000 CCA on load tester: http://www.amazon.com/Shorai-LFX36L3-BS1...f=pd_sbs_auto_6
At the LA Roadster show a battery shop was selling these for car at around $200. He said they did fine for cars with no accessories.
Re: Smallest battery you have used? [Re: autoxcuda] #1527240
11/03/13 03:52 PM
11/03/13 03:52 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
I already have a 13 1/2 pound Genesis that I paid $66 for a few years back that will crank a 17:1 big block with no problems. I'm really interested in seeing if the even smaller and lighter batteries will get the job done. Thanks for the links.
Re: Smallest battery you have used? [Re: John Brown] #1527241
11/03/13 04:33 PM
11/03/13 04:33 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
These lithium batteries are incredible and prices are dropping.
Now check this out...I saw this at a customer that has a AAA tow company with a battery service truck. This will jump 2-3 cars on a single charge. It will fit in you coat pocket. Has 12v, USB and bunch of adapters too.
Check this out, costs around $150 they said.
http://shop.antigravitybatteries.com/micro-start-xp-1/
Re: Smallest battery you have used? [Re: autoxcuda] #1527242
11/03/13 08:27 PM
11/03/13 08:27 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
I am surprised at how affordable the Lithium's have become. Almost makes one rethink the need to relocate battery rearward/trunk with the hassle and additional length/weight of cable needed.
Re: Smallest battery you have used? [Re: jcc] #1527243
11/03/13 10:24 PM
11/03/13 10:24 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
... Almost makes one rethink the need to relocate battery rearward/trunk with the hassle and additional length/weight of cable needed.
I want to put mine under here.
But they are getting small enough maybe I should put it in place of the heater box when I take it out.
Re: Smallest battery you have used? [Re: autoxcuda] #1527244
11/05/13 05:10 PM
11/05/13 05:10 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have a lightweight smaller Odyssey motorcycle battery hidden in my stock style Mopar battery case. looks all stock & saved like 28+ lbs.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Smallest battery you have used? [Re: 6PKRTSE] #1527245
11/05/13 05:11 PM
11/05/13 05:11 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Look like this from the top side.
Re: Smallest battery you have used? [Re: 6PKRTSE] #1527246
11/06/13 01:17 AM
11/06/13 01:17 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Re: Smallest battery you have used? [Re: 6PKRTSE] #1527247
11/07/13 02:40 AM
11/07/13 02:40 AM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
Re: Smallest battery you have used? [Re: Mopar Mitch] #1527248
11/07/13 01:11 PM
11/07/13 01:11 PM
right between milan dragway & ...
Flite_727 Offline
Flite_727  Offline
Read post #80 on this LX forums thread. Interesting info about using Deka batteries as cheap alternatives to Braille. I just googled the ETX30L and they are available under $100.
http://www.lxforums.com/board/f63/weight-reduction-factoids-256293/
'06 Magnum R/T Daily driver, 5.7 N.A.- [email]12.63@109[/email]
Re: Smallest battery you have used? [Re: Flite_727] #1527249
11/08/13 01:26 AM
11/08/13 01:26 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Yea, the Braille's are very expensive. The just look new stickers on the cases that Deka and Phantom use/are.
These seem to be all repackaged restickered deals.
Re: Smallest battery you have used? [Re: 6PKRTSE] #1527250
11/08/13 12:00 PM
11/08/13 12:00 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I used like 4-5 of those type battery's back around 1993-4 in a dragster with a 16-1 572" motor. It turned over the motor fine but could not stand the vibration in a solid rear axle mounted dragster. One good tire shake and a 200 dollar battery was junk. I quite using them for racing because they didn't hold up.
