Re: Smallest battery you have used?
[Re: jcc]
#1527232
11/01/13 11:55 PM
11/01/13 11:55 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I use a CAT battery and have it in the trunk for the counter balance effect. Braille makes super light weight batteries IIRC. Batteries are not somewhere I would skimp on as far as output and reliability go. My car has a stereo too lol.
Mopar to the bone!!!
[Re: Rapom65]
#1527235
11/02/13 02:28 AM
11/02/13 02:28 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
I've seen $150 Lithium's that weight 2 lbs that I'm told will do fine in a car with 210 CCA Can CCA in a Lithium battery be treated different than a old wet battery?? They do have 540 CCA lithiums for $308, but those are 4.96 lbs FATTY's.
[Re: autoxcuda]
#1527236
11/02/13 12:01 PM
11/02/13 12:01 PM
Posts: 22,696 Bitopia
jcc
Bitopia
I'd be fine fine I think with 540 CCA fatty at $308, is the chance of fire with lithium real or very remote?
[Re: autoxcuda]
#1527237
11/03/13 10:13 AM
11/03/13 10:13 AM
Posts: 256 USA
Consulier
USA
What brand? Do you have a link?
[Re: Consulier]
#1527239
11/03/13 12:20 PM
11/03/13 12:20 PM
autoxcuda
So Cal
These are Lithium Motorcycle and ATV batteries. Same applications people were getting the dry cells from.
It seems these batteries are sold under various resellers "labels". I don't know the true manufacturer.
Phantom Battery Shorai Battery
$169: 18 Ah, 270 CCA, L = 5.83”, W = 2.28”, H = 3.50”, 2.31 lbs: http://www.ebay.com/itm/APP18L1-BS12-12V...=p2054897.l4275
$199: 5.5 lbs 12V 21Ah 315CCA: http://www.ebay.com/itm/APP21L6-BS12-12V...=p2054897.l4275
http://www.amazon.com/Shorai-Lithium-Batt-18Ah-LFX18A1-BS12/dp/B007GR5DXE/ref=pd_sbs_auto_1
LFX36L3-BS12, $270, 5.5 pounds, 7.7 x 5.7 x 8 inches, 18AH, read review that it's listed at 520 CCA, other review tested it at 1000 CCA on load tester: http://www.amazon.com/Shorai-LFX36L3-BS1...f=pd_sbs_auto_6
At the LA Roadster show a battery shop was selling these for car at around $200. He said they did fine for cars with no accessories.
[Re: autoxcuda]
#1527240
11/03/13 03:52 PM
11/03/13 03:52 PM
Posts: 1,841 South Bend
John Brown
South Bend
I already have a 13 1/2 pound Genesis that I paid $66 for a few years back that will crank a 17:1 big block with no problems. I'm really interested in seeing if the even smaller and lighter batteries will get the job done. Thanks for the links.
[Re: John Brown]
#1527241
11/03/13 04:33 PM
11/03/13 04:33 PM
autoxcuda
So Cal
These lithium batteries are incredible and prices are dropping. Now check this out...I saw this at a customer that has a AAA tow company with a battery service truck. This will jump 2-3 cars on a single charge. It will fit in you coat pocket. Has 12v, USB and bunch of adapters too. . . . Check this out, costs around $150 they said. http://shop.antigravitybatteries.com/micro-start-xp-1/
[Re: jcc]
#1527243
11/03/13 10:24 PM
11/03/13 10:24 PM
autoxcuda
So Cal
... Almost makes one rethink the need to relocate battery rearward/trunk with the hassle and additional length/weight of cable needed.
I want to put mine under here.
But they are getting small enough maybe I should put it in place of the heater box when I take it out.
[Re: autoxcuda]
#1527244
11/05/13 05:10 PM
11/05/13 05:10 PM
Posts: 4,575 Motor City
6PKRTSE
Motor City
I have a lightweight smaller Odyssey motorcycle battery hidden in my stock style Mopar battery case. looks all stock & saved like 28+ lbs.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#1527245
11/05/13 05:11 PM
11/05/13 05:11 PM
6PKRTSE
Motor City
Look like this from the top side.
[Re: Flite_727]
#1527249
11/08/13 01:26 AM
11/08/13 01:26 AM
autoxcuda
So Cal
Read post #80 on this LX forums thread. Interesting info about using Deka batteries as cheap alternatives to Braille. I just googled the ETX30L and they are available under $100. http://www.lxforums.com/board/f63/weight-reduction-factoids-256293/
Yea, the Braille's are very expensive. The just look new stickers on the cases that Deka and Phantom use/are.
These seem to be all repackaged restickered deals.
[Re: 6PKRTSE]
#1527250
11/08/13 12:00 PM
11/08/13 12:00 PM
Challenger 1
Cincinnati, Ohio
I used like 4-5 of those type battery's back around 1993-4 in a dragster with a 16-1 572" motor. It turned over the motor fine but could not stand the vibration in a solid rear axle mounted dragster. One good tire shake and a 200 dollar battery was junk. I quite using them for racing because they didn't hold up.
