Re: New better cometic head gaskets???
[Re: 70satelliteguy]
#1526022
10/30/13 07:51 PM
10/30/13 07:51 PM
Posts: 7,506 Az
Crizila
Az
Waiting for mine to be delivered. Don't know if they will be the better ones or the worse ones - since I won't know the difference . They did have to make them for my application - I think. On that subject, is everyone putting them in dry or using some type of sealer?
Fastest 300
[Re: Crizila]
#1526023
10/30/13 07:57 PM
10/30/13 07:57 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
I use Coppercoat on mine, inside and both outsides.
If you like drag racing, support your local track.
#1526025
10/30/13 10:39 PM
10/30/13 10:39 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I don't know how recently these "new ones" came out, but I bought mine a couple months back. I had to special order from Cometic to get the correct gaskets for my World aluminum block. (Hemi) I was instructed to smear a little Hylomar on the gaskets around the upper water passages and lower center one. Other wise they were dry. No problems. Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: mshred]
#1526027
10/30/13 11:13 PM
10/30/13 11:13 PM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
[Re: Cab_Burge]
#1526030
10/31/13 10:05 PM
10/31/13 10:05 PM
Posts: 3,415 Toronto
mshred
Toronto
Both
50 RA or smoother
Damn, so that means the engine would have to come out to have the decks surfaced
[Re: mshred]
#1526031
11/01/13 02:29 AM
11/01/13 02:29 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
mshred, For those of us throwing stuff together with less than perfect finishes, and used heads on used blocks and such, ThIS IS WHY WE COPPER COAT em! When you take them off 4 years later with no leaks, guess where the copper coat is, yep, in the low ridges where it's supposed to be.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: MoparBilly]
#1526035
11/01/13 05:04 PM
11/01/13 05:04 PM
mshred
Toronto
Cool! I thought the copper coat was just used to help seal even when the surfaces DO have the proper finish, I wasn't sure it helped seal properly surfaces not correctly machined for them.
Thanks for the info guys!
