New better cometic head gaskets??? #1526021
10/30/13 06:16 PM
10/30/13 06:16 PM
Penna
70satelliteguy Offline OP
Penna
My machine shop says that Cometic is making newer better MLS head gaskets now. He is a Chevy guy. Has anyone seen or heard of them making new ones for Mopars?
Thanks mike
Re: New better cometic head gaskets??? [Re: 70satelliteguy] #1526022
10/30/13 07:51 PM
10/30/13 07:51 PM
Az
Crizila Offline
Crizila  Offline
Az
Waiting for mine to be delivered. Don't know if they will be the better ones or the worse ones - since I won't know the difference . They did have to make them for my application - I think. On that subject, is everyone putting them in dry or using some type of sealer?
Fastest 300
Re: New better cometic head gaskets??? [Re: Crizila] #1526023
10/30/13 07:57 PM
10/30/13 07:57 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
I use Coppercoat on mine, inside and both outsides.
If you like drag racing, support your local track.
Re: New better cometic head gaskets??? [Re: CHAPPER] #1526024
10/30/13 09:06 PM
10/30/13 09:06 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I installed mine per the instructions - dry and have had no issues.
Re: New better cometic head gaskets??? [Re: 70satelliteguy] #1526025
10/30/13 10:39 PM
10/30/13 10:39 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I don't know how recently these "new ones" came out, but I bought mine a couple months back. I had to special order from Cometic to get the correct gaskets for my World aluminum block. (Hemi)
I was instructed to smear a little Hylomar on the gaskets around the upper water passages and lower center one. Other wise they were dry.
No problems.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: New better cometic head gaskets??? [Re: Hemi Allstate] #1526026
10/30/13 10:43 PM
10/30/13 10:43 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Does the deck and the head need a special finish for the Cometic's? Or will just the head surface with a special finish suffice?
Re: New better cometic head gaskets??? [Re: mshred] #1526027
10/30/13 11:13 PM
10/30/13 11:13 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Both
Re: New better cometic head gaskets??? [Re: DJVCuda] #1526028
10/31/13 06:50 PM
10/31/13 06:50 PM
Ohio
3404 Offline
3404  Offline
Ohio
I had issues this spring with my cometics leaking water up the bottom three center sets head studs. I noticed each pair of studs were embossed in the same circle as the water jacket, . Each stud should have been embossed separately or the water jacket itself. I called them and since they are so close a rep cam out to where I had it on the Dyno and said that was a mistake on their part and they had to fix the tooling. They sent me a new set this summer but I have not opened them up yet. We took the set off that was leaking and copper coated them and they have been fine since.
Re: New better cometic head gaskets??? [Re: DJVCuda] #1526029
10/31/13 09:58 PM
10/31/13 09:58 PM
Both
50 RA or smoother
Re: New better cometic head gaskets??? [Re: Cab_Burge] #1526030
10/31/13 10:05 PM
10/31/13 10:05 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Both
50 RA or smoother
Damn, so that means the engine would have to come out to have the decks surfaced
Re: New better cometic head gaskets??? [Re: mshred] #1526031
11/01/13 02:29 AM
11/01/13 02:29 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
mshred,
For those of us throwing stuff together with less than perfect finishes, and used heads on used blocks and such, ThIS IS WHY WE COPPER COAT em! When you take them off 4 years later with no leaks, guess where the copper coat is, yep, in the low ridges where it's supposed to be.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: New better cometic head gaskets??? [Re: MoparBilly] #1526032
11/01/13 09:55 AM
11/01/13 09:55 AM
The Great White North
RAMM Offline
RAMM  Offline
mshred,
I would agree with this. Unless you have a factory finish/or had it resurfaced by someone with a Blockmaster or broach with only one carbide touching. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: New better cometic head gaskets??? [Re: RAMM] #1526033
11/01/13 11:54 AM
11/01/13 11:54 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Ive used dozens of these on Mopar and Brand X engines without any issue..I copper coat them (two heavy coats and install wet)..I even used aluminum matallic paint on one set as I had no copper coat and had no issues..(Ive used the paint before on steel shim gaskets)..
Its best to have nice surfaces, but even on the ones that arent dead perfect, they held up good..
YMMV
MB
Re: New better cometic head gaskets??? [Re: HPMike] #1526034
11/01/13 12:01 PM
11/01/13 12:01 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Ah the old aluminum spray paint trick. You must be old Mike. Lol
Getting old just means you were smarter than some and luckier than others.
Re: New better cometic head gaskets??? [Re: MoparBilly] #1526035
11/01/13 05:04 PM
11/01/13 05:04 PM
Toronto
mshred Offline
mshred  Offline
Toronto
mshred,
Cool! I thought the copper coat was just used to help seal even when the surfaces DO have the proper finish, I wasn't sure it helped seal properly surfaces not correctly machined for them.
Thanks for the info guys!
Re: New better cometic head gaskets??? [Re: DJVCuda] #1526036
11/01/13 05:20 PM
11/01/13 05:20 PM
Penna
Penna
So are there "new" Cometic MLS gaskets for BB Mopars. I last installed mine 2 years ago but have used them several time before. I am going to install new ones but need to know if a newer version has come out???
Thanks Mike
