440 balancer #1521197
10/21/13 09:59 PM
10/21/13 09:59 PM
Home of the Bluegrass
MoparJunkie Offline OP
Hey guys, I was told this was not the original balancer to my 440. So I got a steel crank 440 balancer to replace it, but my pulley won't bolt on? I am including pics of balancer... any feedback would be greatly appreciated.
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: 440 balancer [Re: MoparJunkie] #1521198
10/21/13 10:02 PM
10/21/13 10:02 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Do you have it oriented the right way? One of the six bolt holes is intentionally misaligned so the pulley only bolts on one way.
Try turning it until it lines up.
Some aftermarket pulleys have one slotted hole (or you have to make one slotted hole) to fit this.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: 440 balancer [Re: wingman] #1521199
10/21/13 10:05 PM
10/21/13 10:05 PM
Tried that... It will bolt up what I thought was my so called original. Based on the pics is that a steel crank balancer? My machinist said no???? I honestly thought it was the original???
Re: 440 balancer [Re: MoparJunkie] #1521200
10/21/13 10:16 PM
10/21/13 10:16 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
What do you mean you were told this wasn't the right balancer for your 440 engine. This pic is a 6 pack balancer to confirm can you tell us how thick the offset weight is ? If its 3/16 thick its for a 6 pack engine with heavy rods, and is still a steel crank. If it's thicker its a 400 cast crank balancer. Correct the oreintation of the pulley bolt pattern and it will bolt up. Put the balancer back on the that came off the engine.
MLR426
Re: 440 balancer [Re: MoparJunkie] #1521201
10/22/13 03:35 AM
10/22/13 03:35 AM
If your U code 1970 Charger came with the six pak rods it would have had that balancer also.
Re: 440 balancer [Re: Cab_Burge] #1521202
10/22/13 06:56 AM
10/22/13 06:56 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
Pretty sure that is a "six pack" balancer. You guys correct me if I am wrong, but didn't some 70 440 magnums have the "six pack" rods and crank? If that is correct he will have the heavy rods, and the balancer and torque converter will have weights, externally balanced engine. Greg, did Mike balance the rotating assembly? If he did and used that balancer, you need a duplicate if you are gonna replace it.
jess
Yeah, it's hopped up to over 160...
Re: 440 balancer [Re: jt4406] #1521203
10/22/13 07:46 AM
10/22/13 07:46 AM
He balanced the rotating assembly, but did nothing with the balancer. He said it was weighted and it was the wrong balancer???? I too, thought it should've been the original... So, if he balanced the rotating assembly and not the balancer will I have vibration issues???? Been down that road before!
Re: 440 balancer [Re: MoparJunkie] #1521204
10/22/13 08:41 AM
10/22/13 08:41 AM
Beans Cove Pa
Bumbalawski Offline
Bumbalawski  Offline
Beans Cove Pa
I know of a fellow who has a six pack Superbird. His "machinist" rebuilt the original engine for him. This "machinist" said he did the owner a favor by machining off the counterweight on the dampener and rebalanced the engine. This did not go over with the owner since the 'bird was original and being correctly restored. He had to buy another dampener and rebalance the engine again. This may be your case also less the machined balancer.
If it is correctly balanced, it will not vibrate. But if you have the original torque convertor and it is weighted, the weights need to go. Will it appear correct in the car if the car is a 1970 U code car? No.
Re: 440 balancer [Re: MoparJunkie] #1521205
10/22/13 09:25 AM
10/22/13 09:25 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
Tough to confirm (or disprove) from the pix, but if that pulley has a symmetrical bolt pattern (no offset hole) it is, in fact, a later ('72-up) damper.
If it has the correct weighting needed, it is simple to oval out the one offset hole in the pulley.
Rick
Re: 440 balancer [Re: Rick_Ehrenberg] #1521206
10/22/13 09:54 AM
10/22/13 09:54 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Looks very much like the pictured one has the offset bolt hole. And the H P 440's of 1970 had weighted balancer and heavy(six pac) rods.
Re: 440 balancer [Re: buildanother] #1521207
10/22/13 11:52 AM
10/22/13 11:52 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Shouldn't the keyway line up the holes??
Joe
OOPS!!!! Brain fart
Re: 440 balancer [Re: MoparJunkie] #1521208
10/23/13 09:05 AM
10/23/13 09:05 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Learn your dampers (courtesy of 440 source):
