440 balancer
#1521197
10/21/13 09:59 PM
10/21/13 09:59 PM
Posts: 1,132 Home of the Bluegrass
MoparJunkie
Hey guys, I was told this was not the original balancer to my 440. So I got a steel crank 440 balancer to replace it, but my pulley won't bolt on? I am including pics of balancer... any feedback would be greatly appreciated.
"It takes a Mopar to catch a Mopar” 1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54 2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: 440 balancer
[Re: MoparJunkie]
#1521198
10/21/13 10:02 PM
10/21/13 10:02 PM
Posts: 3,385 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Do you have it oriented the right way? One of the six bolt holes is intentionally misaligned so the pulley only bolts on one way.
Try turning it until it lines up.
Some aftermarket pulleys have one slotted hole (or you have to make one slotted hole) to fit this.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
Re: 440 balancer
[Re: MoparJunkie]
#1521200
10/21/13 10:16 PM
10/21/13 10:16 PM
Posts: 4,799 ILL
MLR426
ILL
What do you mean you were told this wasn't the right balancer for your 440 engine. This pic is a 6 pack balancer to confirm can you tell us how thick the offset weight is ? If its 3/16 thick its for a 6 pack engine with heavy rods, and is still a steel crank. If it's thicker its a 400 cast crank balancer. Correct the oreintation of the pulley bolt pattern and it will bolt up. Put the balancer back on the that came off the engine.
MLR426
Re: 440 balancer
[Re: MoparJunkie]
#1521201
10/22/13 03:35 AM
10/22/13 03:35 AM
Posts: 43,228 Bend,OR USA
Cab_Burge
If your U code 1970 Charger came with the six pak rods it would have had that balancer also.
Re: 440 balancer
[Re: Cab_Burge]
#1521202
10/22/13 06:56 AM
10/22/13 06:56 AM
Posts: 1,567 Ky
jt4406
Ky
Pretty sure that is a "six pack" balancer. You guys correct me if I am wrong, but didn't some 70 440 magnums have the "six pack" rods and crank? If that is correct he will have the heavy rods, and the balancer and torque converter will have weights, externally balanced engine. Greg, did Mike balance the rotating assembly? If he did and used that balancer, you need a duplicate if you are gonna replace it. jess
Yeah, it's hopped up to over 160...
Re: 440 balancer
[Re: jt4406]
#1521203
10/22/13 07:46 AM
10/22/13 07:46 AM
MoparJunkie
He balanced the rotating assembly, but did nothing with the balancer. He said it was weighted and it was the wrong balancer???? I too, thought it should've been the original... So, if he balanced the rotating assembly and not the balancer will I have vibration issues???? Been down that road before!
Re: 440 balancer
[Re: MoparJunkie]
#1521205
10/22/13 09:25 AM
10/22/13 09:25 AM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
Tough to confirm (or disprove) from the pix, but if that pulley has a symmetrical bolt pattern (no offset hole) it is, in fact, a later ('72-up) damper.
If it has the correct weighting needed, it is simple to oval out the one offset hole in the pulley.
Rick
Re: 440 balancer
[Re: buildanother]
#1521207
10/22/13 11:52 AM
10/22/13 11:52 AM
Posts: 1,318 Ohio
jlatessa
Ohio
Shouldn't the keyway line up the holes??
Joe
OOPS!!!! Brain fart
