Need some schooling on Holley carbs? #1520032
10/19/13 05:33 PM
10/19/13 05:33 PM
Houston, Texas
Slant6pak Offline OP
Houston, Texas
Hey guys,
Let me start off by apologizing for my carburetor ignorance. I was unfortunately born too late to have ever owned a daily driver with a carb. My personal experience is mostly limited to cursing Carter BBDs after they have been sitting long enough to empty the float bowls.
I'm working on 71' Road Runner clone that will be powered by (I hope) a healthy 383. I'm trying to build a bit of sleeper than looks fairly close to stock.
My current plan is to run a Holley 750 vacuum secondary carb. IIRC, all factory Mopar 4 barrel carbs were fairly small cfm-wise... 625-650 cfm??
What I'd like to do is buy a cheaper, second hand Holley and "build" a carb that looks fairly correct for a 71' 383 4-speed car.
My questions are:
What used Holley should I look for? I know they are numbered for different makes' linkage style.
Can anybody tell me what features I would find a 71' correct Holley? And can I add them to a A/M carb?
And last question... can somebody point in the right to direction to learn about any new upgrades that I should do for drive-ability, tuning and tolerance to modern gas?
Any help and guidance would be much appreciated
2016 Challenger Scat Pack Shaker smile
1000 ci Brass Era Speedster project
Re: Need some schooling on Holley carbs? [Re: Slant6pak] #1520033
10/19/13 07:01 PM
10/19/13 07:01 PM
There just was a thread on the visual & other differences between the OE/aftermarket holleys several weeks ago iirc. I'm not sure how to search for that. For an aftermarket Holley I'd want one of the clones that has adjustable systems that the OE ones did not have. Not sure if a person could get an OE one & rebuild it & use an aftermarket primary metering block with those adjustable air bleeds etc. I'm not into Holleys very much so my help/info is limited but here's a BTT for ya
Re: Need some schooling on Holley carbs? [Re: Slant6pak] #1520034
10/19/13 09:11 PM
10/19/13 09:11 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Clone? If it was me I would buy a new 800 Thunder AVS, bolt it on and not worry about it.
Sheldon
Re: Need some schooling on Holley carbs? [Re: RUNCHARGER] #1520035
10/19/13 10:25 PM
10/19/13 10:25 PM
Clone?
One of the holley look alikes that's based on the holley system but has the multiple screw in air bleeds etc so you can dial in each system with an A/F meter. People that have went to em (& used the meter to dial em in) swear by em (compared to the older holleys)
Re: Need some schooling on Holley carbs? [Re: RUNCHARGER] #1520036
10/19/13 10:31 PM
10/19/13 10:31 PM
Houston, Texas
Houston, Texas
Sheldon
I would like to stick with Holley carbs.... My 440 Ramcharger will be sporting a trio of them... So only buying jets and goodies for one style of carb would be a plus for me.
Re: Need some schooling on Holley carbs? [Re: Slant6pak] #1520037
10/19/13 10:34 PM
10/19/13 10:34 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
a 3310 will work ok.
If you can find one that has a secondary metering block, those are preferred. You can buy a conversion kit if it does not that uses jets instead of the metering plate system.
Re: Need some schooling on Holley carbs? [Re: Slant6pak] #1520038
10/19/13 10:36 PM
10/19/13 10:36 PM
6 pak (2bbl) carbs are a different animal. I'm not sure what's available for them other than OE carbs or probably repro 6 pak carbs. Someone knowledgeable will help you there. EDIT Oh OK your saying you have a 6 pak in addition to the 71RR, I gotcha now. MORE EDIT It's likely that the clones use holley jets in the air bleeds etc
Re: Need some schooling on Holley carbs? [Re: RapidRobert] #1520039
10/19/13 11:02 PM
10/19/13 11:02 PM
Houston, Texas
Houston, Texas
My six pack for my truck has a hodge podge of OE carbs
Re: Need some schooling on Holley carbs? [Re: Slant6pak] #1520040
10/20/13 10:03 AM
10/20/13 10:03 AM
Minnesota
peabodyracing Offline
Minnesota
My advice is similar to previous postings; look for a list 3310 with the secondary metering block. Adding the block is straightforward if you can't locate one that already has it.
Spend a few minutes looking the carb over thoroughly before buying. I've seen base plates cracked, shaft's wobbling in the base plate, accelerator pump cover screws stripped out and junior high racer mods made to them which generally render them useless for a street car. A favorite seemed to be removing the choke assembly and sometimes milling down the air horn.
Rebuild kits are inexpensive and readily available. Go with the non stick gaskets though. Generally you shouldn't need to increase the accelerator pump. Stay with the vacuum secondary setup. Linkage and brackets available on line. I'm not an expert by any means but have been running these for years. Have only had one that would not work well and turned out to have a crack in the base plate I'd missed. Being up North ours have to be put away for winter. I've always used sea foam in the gas tank before storing and haven't had problems. No other fuel related issues I've run into. Lots of good books available on line if you're so motivated.
Many years ago I had an Offy 2 4 barrel setup with AFB's on my drag car and ran it like that for at least 4 years. On a whim I changed out the intake and put a stock 3310 on the car and first pass out it went 2 tenths of a second quicker than it ever had. Did I feel stupid.
Lead, follow or get the hell out of the way
Re: Need some schooling on Holley carbs? [Re: peabodyracing] #1520041
10/20/13 11:51 AM
10/20/13 11:51 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I am curious why the recommendation to convert the 3310s secondaries to the metering block?
The OP is an admitted novice on carbs. Adding the secondary block does add additional tuning capabilities to the carb, but for someone that does not even know the difference between a 4150 and a 4160, that may not be a good thing.
Besides, the 3310 may be the most popular Holley ever produced and the overwhelming majority have lacked the secondary metering block. Only the very first ones had it.
In my opinion, having a secondary metering block on a 3310 only adds expense and complexity that a beginner tuning a mild engine can't get enough advantages from to justify. Which is why Holley eliminated it many years ago on their most popular entry level model of carb.
One last thought here, weren't the original style of Holley's on the OP's car single inlet carbs? Unlike the dual inlet 3310 style? Point being that they look quite different.
Master, again and still
Re: Need some schooling on Holley carbs? [Re: DaveRS23] #1520042
10/20/13 01:25 PM
10/20/13 01:25 PM
Minnesota
Minnesota
All valid points. I suggested the secondary block because of the OP's statement of a healthy 383. If he decided he needed a little more snort when getting into the secondaries it's simpler to increase jet sizes than figure out metering plates.
Certainly the dual inlet setup will not look oem. My thinking was the best fit for a novice. If I could figure one out certainly the OP could.
Re: Need some schooling on Holley carbs? [Re: peabodyracing] #1520043
10/20/13 04:36 PM
10/20/13 04:36 PM
colorado
a12superbee Offline
a12superbee  Offline
colorado
OP, buy this book,
https://www.google.com/search?q=super+tu...h=730&dpr=1
and no matter which holley box you use, you'll be able to make it work.
I can't afford this. mark
Re: Need some schooling on Holley carbs? [Re: a12superbee] #1520044
10/20/13 04:43 PM
10/20/13 04:43 PM
Lavonia, GA
cjbill Offline
cjbill  Offline
Lavonia, GA
Which book? That link brings up about 5 different books!
ex-Ford guy, but Mopars nowadays
Re: Need some schooling on Holley carbs? [Re: cjbill] #1520045
10/20/13 04:52 PM
10/20/13 04:52 PM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Different versions of the same book for the most part.
I have this one, once you know 'how' it works, getting good performance out of them is pretty easy.
https://www.google.com/shopping/product/...ved=0CGIQ8wIwAg
Re: Need some schooling on Holley carbs? [Re: DaveRS23] #1520046
10/20/13 09:40 PM
10/20/13 09:40 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
I would also advise this, but with nothing in mind about tuning. I worked in a shop restoring carbs for a while. A lot of them seemed to have problems with metering plate warpage. Metering blocks had way fewer problems. This was one thing on my mind when I bought an actual Holley street avenger over other versions on the market.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Need some schooling on Holley carbs? [Re: Michael Ecks] #1520047
10/21/13 09:33 PM
10/21/13 09:33 PM
Houston, Texas
Houston, Texas
Thank you for the replies,
I'm gonna start with the book and go from there.
Re: Need some schooling on Holley carbs? [Re: Slant6pak] #1520048
10/26/13 04:45 PM
10/26/13 04:45 PM
Houston, Texas
Houston, Texas
Okay....
I ended up ordering 3 books on Holley carbs and have done some reading.
I now know the difference between a 4150 and a 4160, and I understand why the 3310 was also recommended.
But I have a new question... it seems that 383s came with 600 cfm carbs, did any Mopar engines use a factory Holley that was 750 cfm?
If so can anybody tell me the list #?
Re: Need some schooling on Holley carbs? [Re: Slant6pak] #1520049
10/26/13 05:08 PM
10/26/13 05:08 PM
I'd think the holley on the 440 would be the largest but I doubt if it was 750 but wait & see what others say on that
Re: Need some schooling on Holley carbs? [Re: Slant6pak] #1520050
10/26/13 07:23 PM
10/26/13 07:23 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The OE Mopar carbs were small. But the factory had to contend with a lot of limiting factors. Timing curves, cam profiles, exhaust, etc all had to be less than optimum to let anybody with a driver's license to be able to floor it under almost any driving conditions.
Which is why bigger cams, hedders, re=curved distributors, al. intakes, and bigger carbs helped our Mopars.
It's not that the Mopar engineers didn't know what they were doing, it is just that they had a ton of constraints that you and I don't.
Throw the 750 on it and rock!
Re: Need some schooling on Holley carbs? [Re: DaveRS23] #1520051
10/27/13 12:15 AM
10/27/13 12:15 AM
Houston, Texas
Houston, Texas
Yeah I know ... just brainstorming.
If I can snag a 3310 or 3310-1 (see I'm learning) I'm going to jump on it.
