Re: minimun piston compression height?
[Re: brownout]
#1519854
10/19/13 06:47 AM
10/19/13 06:47 AM
Posts: 2,091 Delray beach, Florida
Performance Only
A short compression height, 1.094 pin and aluminum rods that leave little room above the pin for valve reliefs all stuffed into a low deck? Why? It sounds like the perfect beginning for a debacle in the making. Change that to a good steel rod and .990 pin (or smaller) and make things a lot easier on yourself.
machine shop owner and engine builder
[Re: viperblue72]
#1519855
10/19/13 08:32 AM
10/19/13 08:32 AM
Posts: 596 Mass.
80fbody
Mass.
Don't know if I should weigh in on this, but I like the 1.32ch. Light piston, but pin isn't into the rings.
The pin is into the oil rings on my 1.32ch KB280 pistons. Not sure if forged would be different.
[Re: 80fbody]
#1519856
10/19/13 09:25 AM
10/19/13 09:25 AM
Posts: 75,047 U.S.S.A.
JohnRR
U.S.S.A.
Forged would be very different if that KB is a hyper piston, though the 1.094 doesn't help. None of the forged .990pin pistons I've had have the pin in the oil ring.
[Re: brownout]
#1519860
10/21/13 07:15 PM
10/21/13 07:15 PM
Posts: 976 ontario canada
mac56
ontario canada
Ok thanks for the infromation I spoke to Koffels and was recommended to keep the compression height to around 1.300 I also told him the application and he said still keep the 1.094 pin vs the .990 pin what do you guys think.
At this point I have the option to change the combo around I was thinking of running a 2.2 rod journal with a piston compression height of 1.3 and some aluminum rods at 6.535 with a .990 pin to lighten things up. Once again this is a nitrous motor that will see a lot of spray.
Dan at performance only helped me pick my B1 pistons and spent a lot of time going over the details of my combo. I also run a 6.535 chev aluminum rod. I think if I remember right the compression height came in at 1.35 and I still ended up with a support rail with 990 pin. Because of Dan's relationship with Diamond he was able to get me what I felt was a great deal for superior parts.
