minimun piston compression height? #1519850
10/19/13 01:22 AM
10/19/13 01:22 AM
ca
brownout Offline OP
brownout  Offline OP
ca
Hey I am building a low deck motor with aluminum rods what do you guys think the minimum piston compression height should be with a 1.094 pin size? The application is going to be a low deck block with 4.5 inch bore and valve pockets for b1 heads and a decent size cam with some duration plus there is going to be a lot of nitrous run through the motor say 500-600 total. I should have room for a 1.20-1.23 compression height hopefully that is enough. Thanks for any advice or experience.
Re: minimun piston compression height? [Re: brownout] #1519851
10/19/13 01:47 AM
10/19/13 01:47 AM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
It will need to be closer to 1.350"-1.400" depending on the valve pocket depths.
Re: minimun piston compression height? [Re: brownout] #1519852
10/19/13 02:24 AM
10/19/13 02:24 AM
ca
brownout Offline OP
brownout  Offline OP
ca
cam card says duration at .050 is 282 on the intake and 294 on the exhaust. lobe lift is 4.850 on the intake and 4.8 on the exhaust so with 1.7 rockers it should be 824/816 before lash and a lsa of 115.
The pistons will probably nee a slight dome to bring the compression up to a desired range.
Re: minimun piston compression height? [Re: brownout] #1519853
10/19/13 05:06 AM
10/19/13 05:06 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Don't know if I should weigh in on this, but I like the 1.32ch. Light piston, but pin isn't into the rings.
Re: minimun piston compression height? [Re: brownout] #1519854
10/19/13 06:47 AM
10/19/13 06:47 AM
Delray beach, Florida
P
Performance Only Offline
P
A short compression height, 1.094 pin and aluminum rods that leave little room above the pin for valve reliefs all stuffed into a low deck? Why? It sounds like the perfect beginning for a debacle in the making.
Change that to a good steel rod and .990 pin (or smaller) and make things a lot easier on yourself.
machine shop owner and engine builder
Re: minimun piston compression height? [Re: viperblue72] #1519855
10/19/13 08:32 AM
10/19/13 08:32 AM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
The pin is into the oil rings on my 1.32ch KB280 pistons. Not sure if forged would be different.
Re: minimun piston compression height? [Re: 80fbody] #1519856
10/19/13 09:25 AM
10/19/13 09:25 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Forged would be very different if that KB is a hyper piston, though the 1.094 doesn't help. None of the forged .990pin pistons I've had have the pin in the oil ring.
Re: minimun piston compression height? [Re: JohnRR] #1519857
10/19/13 10:49 AM
10/19/13 10:49 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I was told by two different piston manufacturers that 1.300 was the minimum CH with B1 valve pockets.
Re: minimun piston compression height? [Re: fbs63] #1519858
10/21/13 03:49 PM
10/21/13 03:49 PM
ca
brownout Offline OP
brownout  Offline OP
ca
Ok thanks for the infromation I spoke to Koffels and was recommended to keep the compression height to around 1.300
I also told him the application and he said still keep the 1.094 pin vs the .990 pin what do you guys think.
At this point I have the option to change the combo around I was thinking of running a 2.2 rod journal with a piston compression height of 1.3 and some aluminum rods at 6.535 with a .990 pin to lighten things up. Once again this is a nitrous motor that will see a lot of spray.
Re: minimun piston compression height? [Re: brownout] #1519859
10/21/13 03:54 PM
10/21/13 03:54 PM
Ok thanks for the infromation Once again this is a nitrous motor that will see a lot of spray.
Make sure and buy a tool steel wrist pin that is thick Maybe the 1.094 size pin will be better also to start with also
Re: minimun piston compression height? [Re: brownout] #1519860
10/21/13 07:15 PM
10/21/13 07:15 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
Dan at performance only helped me pick my B1 pistons and spent a lot of time going over the details of my combo. I also run a 6.535 chev aluminum rod. I think if I remember right the compression height came in at 1.35 and I still ended up with a support rail with 990 pin. Because of Dan's relationship with Diamond he was able to get me what I felt was a great deal for superior parts.
