Hey I am building a low deck motor with aluminum rods what do you guys think the minimum piston compression height should be with a 1.094 pin size? The application is going to be a low deck block with 4.5 inch bore and valve pockets for b1 heads and a decent size cam with some duration plus there is going to be a lot of nitrous run through the motor say 500-600 total. I should have room for a 1.20-1.23 compression height hopefully that is enough. Thanks for any advice or experience.
