Another headlight question, running both low/high beams #1518730
10/17/13 02:55 AM
10/17/13 02:55 AM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
Is there any issue, or would it be harmful, to wire the headlights on my 86 Ramcharger (used the combo low/high light) to function so that on HIGH i get both low and high beams active?
I am going to be deleting the floor mounted dimmer switch as its in the way of where I need to rest my bad leg. So the plan was to add a high beam rocker switch to a blank panel on my dash bezel.
I plan to do a relay conversion on the headlights when I do the dimmer delete. And then run the high beams to there own switch, doing so I wont get the low beam off as is normal with the dimmer switch.
I dont want to let the smoke out of any wires!
Since I live in very active deer country, the extra light makes a big difference.
Part II. Has anyone already done this or a similar conversion, and maybe know what or where I need to look for for wiring on the truck?
Re: Another headlight question, running both low/high beams [Re: hp383] #1518731
10/17/13 03:06 AM
10/17/13 03:06 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
IIRC theres a conversion wiring kit thats is used on GM pickups to do something like that .. I cant see why it wouldnt work on our trucks.. You could always add some road lights aswell..
I am truckless..
Re: Another headlight question, running both low/high beams [Re: 340SHORTY] #1518732
10/17/13 03:08 AM
10/17/13 03:08 AM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
I am adding off road lights on the roof, but sometimes the local LE gets a bit picky about those. A few guys have been getting tickets for not having covers over their lights while on road.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Another headlight question, running both low/high beams [Re: hp383] #1518733
10/17/13 03:15 AM
10/17/13 03:15 AM
DELAWARE
bee71mopar Offline
bee71mopar  Offline
DELAWARE
Re: Another headlight question, running both low/high beams [Re: hp383] #1518734
10/17/13 03:22 AM
10/17/13 03:22 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Yep, illegal around here to unless your offroad and must be covered if they are mounted higher than the head lights..
On my old F250 hiboy I ran a pair og 4" 250 watt aircraft landing light mounted on the bumper.. Worked great on those dark nights..
I am truckless..
Re: Another headlight question, running both low/high beams [Re: hp383] #1518735
10/17/13 02:12 PM
10/17/13 02:12 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Not a good idea.
It will likely overheat the fixture.
Re: Another headlight question, running both low/high beams [Re: hp383] #1518736
10/17/13 02:18 PM
10/17/13 02:18 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
I'm wondering if both beams lit at the same time would actually be brighter, it possibly will only be as bright as the high beam by itself.
Re: Another headlight question, running both low/high beams [Re: hp383] #1518737
10/17/13 02:30 PM
10/17/13 02:30 PM
Lavonia, GA
cjbill Offline
cjbill  Offline
Lavonia, GA
I don't know that it would actually be "that much" brighter. I, myself, added another set of lights to my car. Just be aware, local LE sometimes gets "picky" if you have more than 4 forward beams lit (in total, I have 8 forward beams, or 4 pair on my Subaru). In GA, they don't care, but I was driving in the NE and got asked about it.
Uploaded with ImageShack.us
ex-Ford guy, but Mopars nowadays
Re: Another headlight question, running both low/high beams [Re: John_Kunkel] #1518738
10/17/13 02:56 PM
10/17/13 02:56 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
I know with my 92 Dakota, it has the dimmer on the column. If I pull back on the dimmer, and hold it, I get both low and high beams simultaneously, and it is much brighter than just the high beams.
I dont do that often, or for more than a few seconds when looking out for critters, because I dont want to melt anything.
It sure would be nice to get all the light to the front as possible, but I want to do it without hurting the system, wires, or me.
Re: Another headlight question, running both low/high beams [Re: hp383] #1518739
10/17/13 03:39 PM
10/17/13 03:39 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Remember that an 86 Ramcharger has a single glass bulb on each side. Lighting both elements inside that bulb will likely overheat the bulb itself as well as the plastic adjusting clips and the wire harness.
You have three leads going to those bulbs. Power to the low beam, power to the high beam, and a ground that serves both beams. Feeding the power shouldn't hurt the feeds but that ground wire will be smoking.
Not a good idea.
- Stu Harmon
Re: Another headlight question, running both low/high beams [Re: feets] #1518740
10/17/13 09:15 PM
10/17/13 09:15 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
Remember that an 86 Ramcharger has a single glass bulb on each side. Lighting both elements inside that bulb will likely overheat the bulb itself as well as the plastic adjusting clips and the wire harness....
Not a good idea.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Another headlight question, running both low/high beams [Re: 471Magnum] #1518741
10/17/13 09:35 PM
10/17/13 09:35 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Not a good idea.
, however regarding "brighter", lumens is lumens, percentage wise improvement is the question, and the main intended difference between low and high beams other then the wattage, is the beam spread, and in the hottest/brightest spot directly? ahead I suspect not a big improvement, but to the sides it would be a plus. maybe the best compromise to prevent filament/ glass envelope overheat issues would be a momentary button, can't believe the wiring wouldn't not handle that, unless they share a ground wire.
I like the idea
Re: Another headlight question, running both low/high beams [Re: jcc] #1518742
10/17/13 10:22 PM
10/17/13 10:22 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Daniel Stern Lighting will likely set you up.
I agree the stock wiring will need upgrading, yet by installing a relay circuit and head lamp upgrade you will probably find you do not need both elements 'on' at the same time.
Re: Another headlight question, running both low/high beams [Re: srt] #1518743
10/18/13 04:36 PM
10/18/13 04:36 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
both elements in the same bulb might not be a good idea. separate bulbs I'd say would have worked fine.
Re: Another headlight question, running both low/high beams [Re: jcc] #1518744
10/18/13 05:33 PM
10/18/13 05:33 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Three wires go to each headlight. One for the low beam. One for the high beam. One for ground.
BAD IDEA.
- Stu Harmon
Re: Another headlight question, running both low/high beams [Re: feets] #1518745
10/18/13 09:28 PM
10/18/13 09:28 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
Advise taken.
No dual low/high
Darn...
Re: Another headlight question, running both low/high beams [Re: hp383] #1518746
10/18/13 09:32 PM
10/18/13 09:32 PM
Lavonia, GA
cjbill Offline
cjbill  Offline
Lavonia, GA
Get a nice set of off-road lights, trust me, they can be had second hand rather inexpensively. I ran into the same situation on my '93 truck years back, a couple 8" Bosch lights w/ 100-watt bulbs solved it! I love messing with lighting, I "improve" it on every car I own!
