Re: Another headlight question, running both low/high beams
[Re: hp383]
#1518731
10/17/13 03:06 AM
10/17/13 03:06 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
IIRC theres a conversion wiring kit thats is used on GM pickups to do something like that .. I cant see why it wouldnt work on our trucks.. You could always add some road lights aswell..
I am truckless..
[Re: 340SHORTY]
#1518732
10/17/13 03:08 AM
10/17/13 03:08 AM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
I am adding off road lights on the roof, but sometimes the local LE gets a bit picky about those. A few guys have been getting tickets for not having covers over their lights while on road.
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
[Re: hp383]
#1518736
10/17/13 02:18 PM
10/17/13 02:18 PM
Posts: 25,821 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I'm wondering if both beams lit at the same time would actually be brighter, it possibly will only be as bright as the high beam by itself.
[Re: hp383]
#1518737
10/17/13 02:30 PM
10/17/13 02:30 PM
Posts: 85 Lavonia, GA
cjbill
Lavonia, GA
I don't know that it would actually be "that much" brighter. I, myself, added another set of lights to my car. Just be aware, local LE sometimes gets "picky" if you have more than 4 forward beams lit (in total, I have 8 forward beams, or 4 pair on my Subaru). In GA, they don't care, but I was driving in the NE and got asked about it. Uploaded with ImageShack.us
ex-Ford guy, but Mopars nowadays
[Re: John_Kunkel]
#1518738
10/17/13 02:56 PM
10/17/13 02:56 PM
hp383
State of Confusion
I know with my 92 Dakota, it has the dimmer on the column. If I pull back on the dimmer, and hold it, I get both low and high beams simultaneously, and it is much brighter than just the high beams.
I dont do that often, or for more than a few seconds when looking out for critters, because I dont want to melt anything.
It sure would be nice to get all the light to the front as possible, but I want to do it without hurting the system, wires, or me.
[Re: hp383]
#1518739
10/17/13 03:39 PM
10/17/13 03:39 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Remember that an 86 Ramcharger has a single glass bulb on each side. Lighting both elements inside that bulb will likely overheat the bulb itself as well as the plastic adjusting clips and the wire harness. You have three leads going to those bulbs. Power to the low beam, power to the high beam, and a ground that serves both beams. Feeding the power shouldn't hurt the feeds but that ground wire will be smoking.
Not a good idea.
[Re: jcc]
#1518742
10/17/13 10:22 PM
10/17/13 10:22 PM
Posts: 15,768 Jefferson State
srt
ESYC
ESYC
Jefferson State
Daniel Stern Lighting will likely set you up. I agree the stock wiring will need upgrading, yet by installing a relay circuit and head lamp upgrade you will probably find you do not need both elements 'on' at the same time.
[Re: feets]
#1518745
10/18/13 09:28 PM
10/18/13 09:28 PM
hp383
State of Confusion
Advise taken.
No dual low/high
Darn...
[Re: hp383]
#1518746
10/18/13 09:32 PM
10/18/13 09:32 PM
cjbill
Lavonia, GA
Get a nice set of off-road lights, trust me, they can be had second hand rather inexpensively. I ran into the same situation on my '93 truck years back, a couple 8" Bosch lights w/ 100-watt bulbs solved it! I love messing with lighting, I "improve" it on every car I own!
