What springs with Lunati 60303 voodoo cam? #1518679
10/17/13 12:05 AM
10/17/13 12:05 AM
Jarrettsville, MD
tywebb2 Offline OP
super gas
tywebb2  Offline OP
super gas
Jarrettsville, MD
Just curious what valve springs you guys are running with your 60303 voodoo cam. I am running the springs that came in my eddy heads with 105# seat pressure and car is breaking up at 5700rpm. Called Lunati and they recommended a double spring (73124k4), but I noticed the complete kit they sell with that cam comes with a single spring (73815LUN).
Would simply shimming my existing springs to get seat pressure up be a good idea? With a .060" shim I would be at 120# seat.
'72 440 Cuda
11.673 @ 115.91 w/1.663 60'
Re: What springs with Lunati 60303 voodoo cam? [Re: tywebb2] #1518680
10/17/13 09:22 AM
10/17/13 09:22 AM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
You only change installed height with shims. Adding shims to raise spring pressure is a no no. It could get you into coil bind. Get the correct springs.
Re: What springs with Lunati 60303 voodoo cam? [Re: tywebb2] #1518681
10/17/13 12:25 PM
10/17/13 12:25 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`ve shimmed em before as long as it doesn`t put you into coil bind you should be fine. .120 seems like a lot and looking back on my heads, I think .040 gave me an extra 20 lbs. iirc.
Re: What springs with Lunati 60303 voodoo cam? [Re: tywebb2] #1518682
10/17/13 02:00 PM
10/17/13 02:00 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Call Mike at MRL Performance, he will know exactly what spring to use with that cam.
Mopar to the bone!!!
Re: What springs with Lunati 60303 voodoo cam? [Re: tywebb2] #1518683
10/17/13 02:32 PM
10/17/13 02:32 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Shimming is a band-aid; please put some "real" springs in there and be done with it.
Re: What springs with Lunati 60303 voodoo cam? [Re: tywebb2] #1518684
10/17/13 02:55 PM
10/17/13 02:55 PM
an8sec70cuda Offline
I strongly suggest you call Dwayne Porter (fast68plymouth) and get some springs from him. Dwayne is the man when it comes to this stuff.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What springs with Lunati 60303 voodoo cam? [Re: BradH] #1518685
10/17/13 03:22 PM
10/17/13 03:22 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
If it`s a band aid then some bad ass engine builders I know must not know this............is it ideal no but if the springs are close and were run w/that cam successfully and just need a few lbs. to get back to spec. then it works fine. If the springs are shot or you`re trying to make any spring work then of course not.
Re: What springs with Lunati 60303 voodoo cam? [Re: Thumperdart] #1518686
10/17/13 04:53 PM
10/17/13 04:53 PM
BradH Offline
BradH  Offline
... If the springs are shot or you`re trying to make any spring work then of course not.
That's my point, not that you can't "fine tune" a spring's preload w/in a certain level by the installed height.
But if you're working w/ used springs that only had 120#s closed when new, have fatigued to 110#s after some use, and the new cam really needs 140#s, "You can't get there from here!"
Re: What springs with Lunati 60303 voodoo cam? [Re: BradH] #1518687
10/17/13 05:00 PM
10/17/13 05:00 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That too was my point...........
Re: What springs with Lunati 60303 voodoo cam? [Re: Thumperdart] #1518688
10/17/13 06:02 PM
10/17/13 06:02 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Doing it right the first time almost always has long term benefits
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: What springs with Lunati 60303 voodoo cam? [Re: B3422W5] #1518689
10/17/13 07:42 PM
10/17/13 07:42 PM
Jarrettsville, MD
tywebb2 Offline OP
super gas
tywebb2  Offline OP
super gas
Jarrettsville, MD
I took the springs to a shop today and the measured very close to eddy spec. 125# @ 1.885', 285# @ 1.385, 330# @ 1.285. Guy at the shop said I need a double spring with the voodoo cam.
I called Mike at MRL per advice here and he was super helpful. He recommended a beehive spring part# 74820k1. It is rated 155# @ 1.880, 340# @ 1.380. I also tried calling Dwayne for his advice but the phone was always busy so I didn't get through.
'72 440 Cuda
Re: What springs with Lunati 60303 voodoo cam? [Re: B3422W5] #1518690
10/17/13 11:26 PM
10/17/13 11:26 PM
USA
B3RE Offline
B3RE  Offline
USA
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: What springs with Lunati 60303 voodoo cam? [Re: B3RE] #1518691
10/27/13 04:33 PM
10/27/13 04:33 PM
Jarrettsville, MD
tywebb2 Offline OP
super gas
tywebb2  Offline OP
super gas
Jarrettsville, MD
Just got done putting everything back together this morning after installing the beehive springs Mike at MRL recommended. They did the trick. The Cuda spins up to 6K without a problem now. Thanks again for all the help/advice.
'72 440 Cuda
