What springs with Lunati 60303 voodoo cam?
#1518679
10/17/13 12:05 AM
10/17/13 12:05 AM
Posts: 1,221 Jarrettsville, MD
tywebb2
super gas
super gas
Jarrettsville, MD
Just curious what valve springs you guys are running with your 60303 voodoo cam. I am running the springs that came in my eddy heads with 105# seat pressure and car is breaking up at 5700rpm. Called Lunati and they recommended a double spring (73124k4), but I noticed the complete kit they sell with that cam comes with a single spring (73815LUN).
Would simply shimming my existing springs to get seat pressure up be a good idea? With a .060" shim I would be at 120# seat.
'72 440 Cuda 11.673 @ 115.91 w/1.663 60'
Re: What springs with Lunati 60303 voodoo cam?
[Re: tywebb2]
#1518682
10/17/13 02:00 PM
10/17/13 02:00 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Call Mike at MRL Performance, he will know exactly what spring to use with that cam.
Mopar to the bone!!!
[Re: tywebb2]
#1518684
10/17/13 02:55 PM
10/17/13 02:55 PM
Posts: 13,367 Marion, South Carolina [><]
an8sec70cuda
I strongly suggest you call Dwayne Porter (fast68plymouth) and get some springs from him. Dwayne is the man when it comes to this stuff.
[Re: Thumperdart]
#1518686
10/17/13 04:53 PM
10/17/13 04:53 PM
BradH
... If the springs are shot or you`re trying to make any spring work then of course not.
That's my point, not that you can't "fine tune" a spring's preload w/in a certain level by the installed height.
But if you're working w/ used springs that only had 120#s closed when new, have fatigued to 110#s after some use, and the new cam really needs 140#s, "You can't get there from here!"
[Re: B3422W5]
#1518689
10/17/13 07:42 PM
10/17/13 07:42 PM
tywebb2
super gas
super gas
Jarrettsville, MD
I took the springs to a shop today and the measured very close to eddy spec. 125# @ 1.885', 285# @ 1.385, 330# @ 1.285. Guy at the shop said I need a double spring with the voodoo cam.
I called Mike at MRL per advice here and he was super helpful. He recommended a beehive spring part# 74820k1. It is rated 155# @ 1.880, 340# @ 1.380. I also tried calling Dwayne for his advice but the phone was always busy so I didn't get through.
[Re: B3RE]
#1518691
10/27/13 04:33 PM
10/27/13 04:33 PM
tywebb2
super gas
super gas
Jarrettsville, MD
Just got done putting everything back together this morning after installing the beehive springs Mike at MRL recommended. They did the trick. The Cuda spins up to 6K without a problem now. Thanks again for all the help/advice.
