2005 Hemi Ram stalling at speed #1516370
10/12/13 11:28 PM
10/12/13 11:28 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
My 2005 Hemi Ram has twice now died at an odd time. The first one was at 35mph and I lifted off the gas to coast toward a stop light. It was like I turned the key off. I threw it in neutral and restarted it no problem. It ran fine for the last two months. This morning I was driving down a winding road at about 25mph and I lift off the gas to slow for a corner and was I surprised to have virtually no steering and no brakes to make the corner! I muscled the truck around the corner, slapped it into neutral, and restarted the truck no problem. It ran fine the rest of today. I did the key on/off/on thing and no codes come up. Any ideas? It was pretty scary this morning almost going head on into oncoming traffic.
Re: 2005 Hemi Ram stalling at speed [Re: B1arno] #1516371
10/13/13 12:07 AM
10/13/13 12:07 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Fuel delivery problems may throw no codes yet still occur on occasion.
Re: 2005 Hemi Ram stalling at speed [Re: Kern Dog] #1516372
10/13/13 12:28 AM
10/13/13 12:28 AM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
This brings up an interesting question. I've never experienced a fuel delivery problem in an injected vehicle. Does it differ from a carburated vehicle? Fuel problems I've experienced in the past have kind of sputtered and then died. This was like I turned the key off. Does injection sputter, or does it just go dead?
Re: 2005 Hemi Ram stalling at speed [Re: B1arno] #1516373
10/13/13 12:32 AM
10/13/13 12:32 AM
Winnipeg, MB
sreinheimer Offline
sreinheimer  Offline
Winnipeg, MB
check and see if the throttle body is dirty and clean it. also check trans fluid level
69 Dodge Charger - first full resto 05 Dodge Magnum R/T
Re: 2005 Hemi Ram stalling at speed [Re: B1arno] #1516374
10/13/13 12:45 AM
10/13/13 12:45 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
Smarter guys may chime in after me, but keep in mind that EFI runs at 50 psi or more compared to a 4-6 lbs on a carbureted engine. If the pressure is meant to be at 50 and drops much below that, I'd expect to see a few hiccups.
Re: 2005 Hemi Ram stalling at speed [Re: Kern Dog] #1516375
10/13/13 10:36 AM
10/13/13 10:36 AM
Oak Harbor, WA
W
Wicked49670dart Offline
W
Oak Harbor, WA
So from your post, acts like the key is just turn off while driving. Most of the time a fuel pump will act as if you are running out of fuel, from what you described sounds like a crank sensor. Do you have a scan tool to check for codes and read cam/crank sensor data? Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: 2005 Hemi Ram stalling at speed [Re: B1arno] #1516376
10/13/13 10:43 AM
10/13/13 10:43 AM
S.E.Mich
drew72 Offline
drew72  Offline
S.E.Mich
Port injected vehicles will feel like they just died. It takes full fuel pressure to open the injectors.
Re: 2005 Hemi Ram stalling at speed [Re: drew72] #1516377
10/13/13 11:28 AM
10/13/13 11:28 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Fuel pressure does not open injectors...electrical current flow does. Because this vehicle starts right back up,I'm not sure it's fuel pressure(if it was it would require extended crank time to build pressure again) My thoughts go with the dirty throttle body(both times it acted up was in a closed throttle position)my second guess would go with the crank sensor...a scan tool capable of watching data at the time of failure will be helpful here. Good luck with it
Re: 2005 Hemi Ram stalling at speed [Re: Wicked49670dart] #1516378
10/13/13 11:58 AM
10/13/13 11:58 AM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
I do not have a sacan tool but I think I can borrow one. I've had bad cam sensors show up with the key on/off trick and I'm assuming a bad crank sensor would show up there too. Could one of them just not be "bad enough" to show up.
Re: 2005 Hemi Ram stalling at speed [Re: B1arno] #1516379
10/13/13 12:02 PM
10/13/13 12:02 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
I'll also do a quick cleaning of the throttle body today.
Thanks everyone for the input!
Re: 2005 Hemi Ram stalling at speed [Re: B1arno] #1516380
10/13/13 12:20 PM
10/13/13 12:20 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Did you just top off the gas tank?
Ran into a similar issue with my wife's 05 Ram, but it was right after a fill the tank up completely top off.
It was the solenoid that vents the tank being stuck open. Gas would slosh up it and drown out the engine. New solenoid fixed it, under warranty and I had to point it out to them. I believe there is a TSB on it, but it's been a few years.
Don't be the exception.
Re: 2005 Hemi Ram stalling at speed [Re: B1arno] #1516381
10/13/13 12:49 PM
10/13/13 12:49 PM
Oak Harbor, WA
W
W
Oak Harbor, WA
Intermittent problems are tuff to find, I would check the crank sensor and its wiring. Make sure there's no corrosion, road dirt/mud in connector, make sure sensor is mounted correctly. You can lightly tap on crank sensor with the engine running and see if the engine stalls. Matt
Re: 2005 Hemi Ram stalling at speed [Re: sreinheimer] #1516382
10/13/13 11:57 PM
10/13/13 11:57 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
This is what you want to do. It sounds like a dirty throttle body as you say it stalls when you let off the gas. And check the trans fluid in nuetral and not Park. The 45 and 545RFE's can stall if trans fluid it to low because the fluid on that trans holds the lock-up converter off and if it gets low on fluid I have seen them partially lock the converter and stall the eng. These lock-ups work a little different then the other Mopar trannys as on the 45 and 545RFE trannys the fluid pushes the lock-up converter off. When it locks up it will change the fluid direction and let the lock-up clutch engage which can happen when low on trans fluid as it may not have enough fluid there to hold the converter off if low on fluid and it will be just like letting the clutch out on a stick car when stopped and stall the eng. Ron
Re: 2005 Hemi Ram stalling at speed [Re: 383man] #1516383
10/14/13 08:42 PM
10/14/13 08:42 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
It was not right after filling the tank. It was at about 3/4. I checked the trans fluid today and it is perfect. Back to the throttle body. haven't had a chance to clean it yet. Ran fine all day today.
Thanks everyone
Arno
Re: 2005 Hemi Ram stalling at speed [Re: B1arno] #1516384
10/16/13 02:28 PM
10/16/13 02:28 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
My buddy had the same issue with his 2004 Hemi - Long story but it ended up being the computer.
He's been a mechanic for 24 years and spent alot of time trying to figure it out but it took a dealer tech to find the problem
