Re: 2005 Hemi Ram stalling at speed
[Re: B1arno]
#1516373
10/13/13 12:32 AM
10/13/13 12:32 AM
Posts: 163 Winnipeg, MB
sreinheimer
Winnipeg, MB
check and see if the throttle body is dirty and clean it. also check trans fluid level
69 Dodge Charger - first full resto
05 Dodge Magnum R/T
[Re: B1arno]
#1516374
10/13/13 12:45 AM
10/13/13 12:45 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
This was like I turned the key off. Does injection sputter, or does it just go dead?
Smarter guys may chime in after me, but keep in mind that EFI runs at 50 psi or more compared to a 4-6 lbs on a carbureted engine. If the pressure is meant to be at 50 and drops much below that, I'd expect to see a few hiccups.
[Re: B1arno]
#1516376
10/13/13 10:43 AM
10/13/13 10:43 AM
Posts: 343 S.E.Mich
drew72
S.E.Mich
This brings up an interesting question. I've never experienced a fuel delivery problem in an injected vehicle. Does it differ from a carburated vehicle? Fuel problems I've experienced in the past have kind of sputtered and then died. This was like I turned the key off. Does injection sputter, or does it just go dead?
Port injected vehicles will feel like they just died. It takes full fuel pressure to open the injectors.
[Re: drew72]
#1516377
10/13/13 11:28 AM
10/13/13 11:28 AM
Posts: 4,961 WI
Dcuda69
WI
Fuel pressure does not open injectors...electrical current flow does. Because this vehicle starts right back up,I'm not sure it's fuel pressure(if it was it would require extended crank time to build pressure again) My thoughts go with the dirty throttle body(both times it acted up was in a closed throttle position)my second guess would go with the crank sensor...a scan tool capable of watching data at the time of failure will be helpful here. Good luck with it ![](/ubbthreads/images/graemlins/beer.gif)
[Re: Wicked49670dart]
#1516378
10/13/13 11:58 AM
10/13/13 11:58 AM
Posts: 1,039 Redwood City Ca.
B1arno
Redwood City Ca.
So from your post, acts like the key is just turn off while driving. Most of the time a fuel pump will act as if you are running out of fuel, from what you described sounds like a crank sensor. Do you have a scan tool to check for codes and read cam/crank sensor data? Matt
I do not have a sacan tool but I think I can borrow one. I've had bad cam sensors show up with the key on/off trick and I'm assuming a bad crank sensor would show up there too. Could one of them just not be "bad enough" to show up.
[Re: sreinheimer]
#1516382
10/13/13 11:57 PM
10/13/13 11:57 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
This is what you want to do. It sounds like a dirty throttle body as you say it stalls when you let off the gas. And check the trans fluid in nuetral and not Park. The 45 and 545RFE's can stall if trans fluid it to low because the fluid on that trans holds the lock-up converter off and if it gets low on fluid I have seen them partially lock the converter and stall the eng. These lock-ups work a little different then the other Mopar trannys as on the 45 and 545RFE trannys the fluid pushes the lock-up converter off. When it locks up it will change the fluid direction and let the lock-up clutch engage which can happen when low on trans fluid as it may not have enough fluid there to hold the converter off if low on fluid and it will be just like letting the clutch out on a stick car when stopped and stall the eng. Ron
