Re: What Solid Roller Lifters Do You Use
[Re: Thumperdart]
#1516166
10/12/13 03:32 PM
10/12/13 03:32 PM
Posts: 9,871 MI, usa
dvw
MI, usa
I run Comp 892 Endure X. 95 passes with out issue. Lash stays constant. 285@.050" .799" cam. My block is bushed and I push rod oil. Doug
[Re: J_BODY]
#1516168
10/12/13 03:59 PM
10/12/13 03:59 PM
Posts: 20,660 in a cattle trailer down by th...
Guitar Jones
I'm using Cranes that could be used for pushrod oiling but I don't. Unbushed block, Trend pushrods and HS rockers.
[Re: Darryls-Demon]
#1516172
10/12/13 11:39 PM
10/12/13 11:39 PM
Posts: 3,456 Out West
408strokerdart
Out West
The best lifter on the market will not last if the rest of the valve train is not up to par. That being said it is always good to buy the best lifter you can afford. Also have the cam ground so you can run a tight lash.
This is the best answer so far in my opinion.
Don't skimp on the lifters and make sure the person setting up the valve train knows what they are doing. If you do not "control" the valve you will damage the lifters no matter what lifter you put in.
