What Solid Roller Lifters Do You Use #1516164
10/12/13 02:52 PM
10/12/13 02:52 PM
western PA
Sb Valiant Offline OP
western PA
I'm just wondering what brand of lifters comp, lunati, doug herbert, crane, ect have you used and have had good luck with.
Re: What Solid Roller Lifters Do You Use [Re: Sb Valiant] #1516165
10/12/13 02:57 PM
10/12/13 02:57 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Isky solid bodys in a stock unbushed block...........
Re: What Solid Roller Lifters Do You Use [Re: Thumperdart] #1516166
10/12/13 03:32 PM
10/12/13 03:32 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I run Comp 892 Endure X. 95 passes with out issue. Lash stays constant. 285@.050" .799" cam. My block is bushed and I push rod oil.
Doug
Re: What Solid Roller Lifters Do You Use [Re: dvw] #1516167
10/12/13 03:39 PM
10/12/13 03:39 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
we ran some comp cam roller lifters in our W5 motor. 50 passes into the new mill we had water leaking issues and tore the engine down. Didn't have anything to do with the water, but we did find four of the comp roller lifter bodies cracked. Went to thicker pushrods and some new lifters from IMM and the prob went away. No clue as to why they cracked, but could have been a harmonics issue rather than a product issue... or not. who knows. lifter bores not bushed, and pushrod oiled here too.
Re: What Solid Roller Lifters Do You Use [Re: J_BODY] #1516168
10/12/13 03:59 PM
10/12/13 03:59 PM
Guitar Jones Offline
I'm using Cranes that could be used for pushrod oiling but I don't. Unbushed block, Trend pushrods and HS rockers.
Re: What Solid Roller Lifters Do You Use [Re: J_BODY] #1516169
10/12/13 04:02 PM
10/12/13 04:02 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
The best lifter on the market will not last if the rest of the valve train is not up to par. That being said it is always good to buy the best lifter you can afford.
Also have the cam ground so you can run a tight lash.
Re: What Solid Roller Lifters Do You Use [Re: Sb Valiant] #1516170
10/12/13 04:10 PM
10/12/13 04:10 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Not a place you want to skimp on cost!!!
Re: What Solid Roller Lifters Do You Use [Re: Darryls-Demon] #1516171
10/12/13 04:24 PM
10/12/13 04:24 PM
western PA
western PA
I know this has nothing to do with anything but does anyone know how the solid roller engines get there sound like a typewriter or thrashing machine? It's like the
valve train starts speeding up going into a certain rythm lol. Does that have any thing
to do with the valve lash or the fact everything is a roller. Cam, lifters, rockers. I know it's the whole combo but it generally relates in the valve train.
Re: What Solid Roller Lifters Do You Use [Re: Darryls-Demon] #1516172
10/12/13 11:39 PM
10/12/13 11:39 PM
Out West
408strokerdart Offline
Out West
This is the best answer so far in my opinion.
Don't skimp on the lifters and make sure the person setting up the valve train knows what they are doing. If you do not "control" the valve you will damage the lifters no matter what lifter you put in.
Re: What Solid Roller Lifters Do You Use [Re: 408strokerdart] #1516173
10/12/13 11:56 PM
10/12/13 11:56 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
jesel or cam fx ...just me
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
