Griner VB guys - line pressure qun #1514410
10/09/13 10:35 AM
10/09/13 10:35 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Hey guys I just wondering what kinda line pressure you guys run with a LBA Griner TB/VB ?
The trans has a 3.2 lever in an 800HP Hemi application.
Also, which port do you use to check the fluid pressure in the 727 ?
Thanks !!
Re: Griner VB guys - line pressure qun [Re: LAD 524] #1514411
10/09/13 12:12 PM
10/09/13 12:12 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
180 lbs per instructions REAR servo with brake on
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Griner VB guys - line pressure qun [Re: 440lebaron] #1514412
10/09/13 01:45 PM
10/09/13 01:45 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
I use the 4.2 lever
Why the 3 lever?
Re: Griner VB guys - line pressure qun [Re: Sammy] #1514413
10/09/13 06:26 PM
10/09/13 06:26 PM
Portsmouth, VA
DusterW2 Offline
DusterW2  Offline
Portsmouth, VA
With a Griner VB (high line pressure and high volume fluid circuits) you don't need high ratio levers. Some even use a 2.9. With a lower ratio, there is less chance of direct clutch/kickdown band timing problems.
John
7881669-12-22G20B.pdf (162 downloads)
Re: Griner VB guys - line pressure qun [Re: DusterW2] #1514414
10/09/13 08:35 PM
10/09/13 08:35 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
From memory they are factory set to 190 psi
Alan Jones
Re: Griner VB guys - line pressure qun [Re: LA360] #1514415
10/10/13 10:22 AM
10/10/13 10:22 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Thanx Al - which port on the case is used to check like pressure ?
Re: Griner VB guys - line pressure qun [Re: LAD 524] #1514416
10/10/13 02:58 PM
10/10/13 02:58 PM
Backwater, PA
bwdst6 Offline
Bob George Racing #1 Fan
bwdst6  Offline
Backwater, PA
As an FYI. The more line pressure you run the more the pump works and the more parasitic lose you have from said pump. IOW, more line pressure robs HP and Griners have a lot of line pressure!
This post is available in double vision where drunk.
Re: Griner VB guys - line pressure qun [Re: bwdst6] #1514417
10/10/13 05:44 PM
10/10/13 05:44 PM
LA360 Offline
LA360  Offline
Comp Eliminator guys will wind the line pressure down to around 80 psi
190 psi might have been the max, and 165 psi was standard, my memory is fading....
Alan Jones
Re: Griner VB guys - line pressure qun [Re: bwdst6] #1514418
10/10/13 06:09 PM
10/10/13 06:09 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Very true.
Griner does such a good job with shift overlap though that I think his valvebodies might perhaps offset the pressure liability. And his brake releases super quick for pro tree stuff.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Griner VB guys - line pressure qun [Re: B3422W5] #1514419
10/13/13 07:20 AM
10/13/13 07:20 AM
Deep DEEP SOUTH
LAD 524 Offline OP
LAD 524  Offline OP
Deep DEEP SOUTH
Thanks fellas....
As an aside, Im also curious as to what band adjustment is use on F&R bands with the Griner VB and a 3.2 lever?
