Griner VB guys - line pressure qun
#1514410
10/09/13 10:35 AM
10/09/13 10:35 AM
Posts: 623 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
Hey guys I just wondering what kinda line pressure you guys run with a LBA Griner TB/VB ?
The trans has a 3.2 lever in an 800HP Hemi application.
Also, which port do you use to check the fluid pressure in the 727 ?
Thanks !!
Re: Griner VB guys - line pressure qun
[Re: LAD 524]
#1514411
10/09/13 12:12 PM
10/09/13 12:12 PM
Posts: 1,610 westerly, ri. usa
440lebaron
westerly, ri. usa
180 lbs per instructions REAR servo with brake on
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: LAD 524]
#1514416
10/10/13 02:58 PM
10/10/13 02:58 PM
Posts: 970 Backwater, PA
bwdst6
Bob George Racing #1 Fan
Backwater, PA
As an FYI. The more line pressure you run the more the pump works and the more parasitic lose you have from said pump. IOW, more line pressure robs HP and Griners have a lot of line pressure!
This post is available in double vision where drunk.
[Re: bwdst6]
#1514417
10/10/13 05:44 PM
10/10/13 05:44 PM
Posts: 6,148 Melbourne , Australia
LA360
Comp Eliminator guys will wind the line pressure down to around 80 psi 190 psi might have been the max, and 165 psi was standard, my memory is fading....
Alan Jones
