Clutch disc 4 speed which one #1512253
10/04/13 06:57 PM
10/04/13 06:57 PM
yellow70charger Offline OP
IF you were going to replace the clutch disc what would go with 69 charger 440 11inch
http://www.summitracing.com/search/year/...&keyword=18
Thanks James
Re: Clutch disc 4 speed which one [Re: yellow70charger] #1512254
10/04/13 08:08 PM
10/04/13 08:08 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Back in the day I used to run Hayes Clutches with good results but...
Now a days I always go for a Center Force set up, they are easy on your leg and grab as good or better then the old 3 finger.
Re: Clutch disc 4 speed which one [Re: RJS] #1512255
10/04/13 08:58 PM
10/04/13 08:58 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree Cf all the way.I ran McCleods for years.12 years ago i put in the CF.Great clutch and it hooks hard behind my 440 pushing over 500 hp.Rocky
Chrysler Firepower
Re: Clutch disc 4 speed which one [Re: therocks] #1512256
10/04/13 10:53 PM
10/04/13 10:53 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I like the CF dual friction. if installed (IE: surface or replace the flywheel) and broke in properly, ZERO issues
Re: Clutch disc 4 speed which one [Re: TJP] #1512257
10/04/13 11:23 PM
10/04/13 11:23 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Ram
Re: Clutch disc 4 speed which one [Re: GTX MATT] #1512258
10/05/13 12:26 AM
10/05/13 12:26 AM
Truckville, the capital of NY
85_Ram_4speed Offline
If you are replacing just the disc, then you need to know what pressure plate you are dealing with as far as its load capability in pounds. This coupled with which material your clutch disc currently is and how you like the performance may dictate what you get to put in it.
If you are going a new set of disc and pressure plate, then that becomes a little easier. I have used the CF dual friction set up, and while it does work good, when you launch or are power shifting it, its almost like its on or off. It engages harsh and fast doing that kind of stuff, but it does hold very well, and is rather friendly, driving it normally on the street where you'll be slipping it a bit. I almost think for a vehicle that is more street than race, something like the CF DF setup or even a Mcleod dual disc would be the way to go. But if you are more race orientated, maybe look into something else that is less harsh---but then you loose some drivability (ability to screw around) on the street.
Outcast Dodge guy.
Re: Clutch disc 4 speed which one [Re: yellow70charger] #1512259
10/05/13 10:18 AM
10/05/13 10:18 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have this one on the shelf in case you want it.
Gus
64 Plymouth Savoy
Dana 60
