A-618 transmission ID help needed #1511542
10/02/13 04:48 PM
10/02/13 04:48 PM
Tampa, FL
tpabayflyer Offline OP
Tampa, FL
I recently purchased an A618 overdrive trans and there are no 46RH/47RH markings at all to be found? this is a 3 pin plugin so it is a L/U converter. 1993 is cast in on the tailshaft so I assume that is the year.? here is what is stamped on the drivers side pad just above the pan:
PK52118307 1732 2722
supposedly this was rebuilt but I want to know what I have as I may want to make some upgrades as this will be going behind Hemi if JW ever makes there ultrabells again! TIA TBF
71 Challenger 528 Hemi project
09 Gr Cherokee 5.7 hemi in da house!!
Re: A-618 transmission ID help needed [Re: tpabayflyer] #1511543
10/02/13 06:11 PM
10/02/13 06:11 PM
Tampa, FL
Tampa, FL
Also, how do you tell if it is a diesel bellhousing or gas? this one has a cutout about 1" wide and 1" deep at the 11 oclock position if looking at the front pump.....
Re: A-618 transmission ID help needed [Re: tpabayflyer] #1511544
10/02/13 06:20 PM
10/02/13 06:20 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
618 is diesel V10 only , they use the same bellhousing , the diesel has a adapter to fit the V10 pattern.
Re: A-618 transmission ID help needed [Re: JohnRR] #1511545
10/02/13 06:46 PM
10/02/13 06:46 PM
Houston
I
it's Bob Offline
it's Bob  Offline
I
Houston
The cutout on the bell is for the crank position sensor.
Re: A-618 transmission ID help needed [Re: tpabayflyer] #1511546
10/02/13 07:07 PM
10/02/13 07:07 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
PK52118307 is a 46RH from behind a '92-'95 318 2WD.
Re: A-618 transmission ID help needed [Re: John_Kunkel] #1511547
10/02/13 07:45 PM
10/02/13 07:45 PM
Tampa, FL
Tampa, FL
Thanks a bunch John.. so this would be a standard a518 trans.... now what should I do to make it live behind a hemi???
Re: A-618 transmission ID help needed [Re: tpabayflyer] #1511548
10/02/13 08:00 PM
10/02/13 08:00 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
That's easy... It's basically a 727 with overdrive.... as is the 618 tranny.
Re: A-618 transmission ID help needed [Re: tpabayflyer] #1511549
10/02/13 11:01 PM
10/02/13 11:01 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Everything you would do to a 727 and build the OD unit to diesel spec... as a starter.
