A-618 transmission ID help needed
#1511542
10/02/13 04:48 PM
10/02/13 04:48 PM
Posts: 1,586 Tampa, FL
tpabayflyer
Tampa, FL
I recently purchased an A618 overdrive trans and there are no 46RH/47RH markings at all to be found? this is a 3 pin plugin so it is a L/U converter. 1993 is cast in on the tailshaft so I assume that is the year.? here is what is stamped on the drivers side pad just above the pan: PK52118307 1732 2722 supposedly this was rebuilt but I want to know what I have as I may want to make some upgrades as this will be going behind Hemi if JW ever makes there ultrabells again! TIA TBF
71 Challenger 528 Hemi project 09 Gr Cherokee 5.7 hemi in da house!!
Re: A-618 transmission ID help needed
[Re: tpabayflyer]
#1511543
10/02/13 06:11 PM
10/02/13 06:11 PM
tpabayflyer
Tampa, FL
Also, how do you tell if it is a diesel bellhousing or gas? this one has a cutout about 1" wide and 1" deep at the 11 oclock position if looking at the front pump.....
[Re: tpabayflyer]
#1511546
10/02/13 07:07 PM
10/02/13 07:07 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
PK52118307 is a 46RH from behind a '92-'95 318 2WD.
[Re: John_Kunkel]
#1511547
10/02/13 07:45 PM
10/02/13 07:45 PM
tpabayflyer
Tampa, FL
Thanks a bunch John.. so this would be a standard a518 trans.... now what should I do to make it live behind a hemi???
[Re: tpabayflyer]
#1511549
10/02/13 11:01 PM
10/02/13 11:01 PM
Posts: 74,907 U.S.S.A.
JohnRR
U.S.S.A.
Everything you would do to a 727 and build the OD unit to diesel spec... as a starter.
