Re: Two thumbs up to IMM engines [Re: Darryls-Demon] #1509166
09/29/13 06:47 PM
09/29/13 06:47 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
What block do you use? Did you bush the lifter bores?
matt
Mid 70s 360 block, lifter bores are not bushed.
Did you use AMC lifters? They oil through the push rod. Brian did my heads and speced my cam for me. Do you have an up close picture of your rocker set up? thx matt
[img] [/img]
Re: Two thumbs up to IMM engines [Re: Darryls-Demon] #1509167
09/29/13 06:54 PM
09/29/13 06:54 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Darryl... you mentioned gear change. Assuming a whole new pig, or are you still running that aluminum center section?
Re: Two thumbs up to IMM engines [Re: clonestocker] #1509168
09/29/13 08:45 PM
09/29/13 08:45 PM
Glendale Az
Darryls-Demon Offline OP
Glendale Az
matt
I do not remember the part number of the lifters Matt, Brian ordered them.
This is the best pic of the rockers that I have.
Re: Two thumbs up to IMM engines [Re: J_BODY] #1509169
09/29/13 08:49 PM
09/29/13 08:49 PM
Glendale Az
Glendale Az
Yes Jay the 3.73s are in the aluminum center section.
Re: Two thumbs up to IMM engines [Re: Darryls-Demon] #1509170
09/29/13 09:40 PM
09/29/13 09:40 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
a view of the tail lights. my comp lifters that were in my BB for 5-6 years looked like new also
Re: Two thumbs up to IMM engines [Re: Darryls-Demon] #1509171
09/29/13 09:44 PM
09/29/13 09:44 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
probably these Matt...
we got these from Brian on "round 2" of our W5 adventure. No bushings in our stock block either. Oil through pushrod.
Re: Two thumbs up to IMM engines [Re: J_BODY] #1509172
09/29/13 10:40 PM
09/29/13 10:40 PM
michigan woods
imfixinmopars426 Offline
michigan woods
I bought a 408/360 combo from brian,and what a gentleman!!! you know,when you get all done,and you actually feel GOOD about the purchase,you know you picked the right guy...BRIAN!!
Re: Two thumbs up to IMM engines [Re: imfixinmopars426] #1509173
09/30/13 02:05 AM
09/30/13 02:05 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
you guys that are gittin all these miles out of your roller lifters,what spring press.are you runnin?
Re: Two thumbs up to IMM engines [Re: bonefish] #1509174
09/30/13 12:32 PM
09/30/13 12:32 PM
SoCal
Brian Hafliger Offline
SoCal
Thank you Daryl and everyone else for the positive comments!
Those are Comp 8043-16 lifters.
Valve train life is more about lobe choice, rpm, toss weight, and spring used than anything. It all has to work in harmony or you'll get shorter life.
Using quality components like the TD rockers is KEY to valvetrain life and stability!! Very important.
Brian Hafliger
Re: Two thumbs up to IMM engines [Re: sixpackgut] #1509175
09/30/13 10:09 PM
09/30/13 10:09 PM
Glendale Az
Glendale Az
Let me guess Ray I was moving so slow you thought I was one of the check points so you snapped that photo.
Re: Two thumbs up to IMM engines [Re: bonefish] #1509176
09/30/13 10:12 PM
09/30/13 10:12 PM
Glendale Az
Glendale Az
The spring pressures are 200 on the seat and 500 open.
