How to get 340 right side exhaust off? #150885
11/14/08 03:44 PM
11/14/08 03:44 PM
BDW Online content OP
BDW  Online Content OP
I'm gussing this shouldn't be that hard! I have all the nuts off, and the stud in the 1st spot (closet to radiator). But I can't remove the manifold, it hits the fenderwell by the #2 stud.
What's the trick?
Thx
Re: How to get 340 right side exhaust off? [Re: BDW] #150886
11/14/08 03:48 PM
11/14/08 03:48 PM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
Pull the other studs......
Re: How to get 340 right side exhaust off? [Re: BDW] #150887
11/14/08 03:59 PM
11/14/08 03:59 PM
loosen the motor mounts (& whatever else needs to be loosened) & jack the front of the eng up just far enough to slide it out.
Re: How to get 340 right side exhaust off? [Re: RapidRobert] #150888
11/14/08 04:02 PM
11/14/08 04:02 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
That looks like a b or e body looking at the shock tower.is the engine sitting center on the k frame. There should be enough clearance for it just slide off.
Re: How to get 340 right side exhaust off? [Re: BDW] #150889
11/14/08 04:11 PM
11/14/08 04:11 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Pull that stud out, the rest might clear with little bit of angle.
Re: How to get 340 right side exhaust off? [Re: formula_s] #150890
11/14/08 04:14 PM
11/14/08 04:14 PM
It's a Challenger. It would be very difficult to remove that stud. It doesn't stick out.
It seems like the motor should go down. I would have to raise the motor pretty high to get past the interference.
Where could I safely put a jack to raise the motor if that is the only solution?
Re: How to get 340 right side exhaust off? [Re: BDW] #150891
11/14/08 04:17 PM
11/14/08 04:17 PM
A bottle jack & a small piece of wood under one of the oil pan bolts in the front
Re: How to get 340 right side exhaust off? [Re: RapidRobert] #150892
11/16/08 09:03 PM
11/16/08 09:03 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Watch your clearance between the top of the bell housing and the firewall, that will probably be your limiting factor if you've dropped the head pipes off.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: How to get 340 right side exhaust off? [Re: GO_Fish] #150893
11/16/08 09:21 PM
11/16/08 09:21 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
maybe try jacking up just that side ???
Re: How to get 340 right side exhaust off? [Re: JohnRR] #150894
11/16/08 09:26 PM
11/16/08 09:26 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
i thought studs are only on the outsides of the mani....
Re: How to get 340 right side exhaust off? [Re: AARCONV] #150895
11/16/08 10:04 PM
11/16/08 10:04 PM
JohnRR Offline
JohnRR  Offline
that spot uses the long nut , so it would be a stud also
Re: How to get 340 right side exhaust off? [Re: JohnRR] #150896
11/16/08 10:10 PM
11/16/08 10:10 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
long sleeve nut, and if the nut is seized to the stud, the stud comes out also, extending the problem by another 1/2" (pardon the pun) .
Re: How to get 340 right side exhaust off? [Re: GO_Fish] #150897
11/16/08 10:33 PM
11/16/08 10:33 PM
Niagara, Ontario Canada
mrpatel Offline
mrpatel  Offline
Go easy, I ended up snapping 2 and ended up pulling my heads to drill and tap. Take your time, you'll get it, I would suggest lots of penetrating fluid (heat it up first, then spraying it will also help to suck in the WD-40 if needed).
Re: How to get 340 right side exhaust off? [Re: mrpatel] #150898
11/16/08 10:50 PM
11/16/08 10:50 PM
I unbolt a 1/2 turn then go back the other way a skosh then unbolt another 1/2 turn like when you are cuttng threads with a tap. this has kept me from snapping many bolts/studs
Re: How to get 340 right side exhaust off? [Re: RapidRobert] #150899
11/16/08 11:42 PM
11/16/08 11:42 PM
Kansas
Menzaero Offline
Menzaero  Offline
Kansas
I just did this on my 70 Dart Swinger to replace a blown head gasket. Here is what I did to get the exhaust manifold off.
1. Unbolt the head pipe from the manifold.
2. Loosen the head pipe from the manifold on the drivers side but leave the bolt and nut connected.
3. Loosen both motor mounts but leave the nut on the bolt.
4. Remove the transmission cross-member and put a bottle jack under the transmission to support.(727 Transmission on my car)
5.Remove distributor, carb, linkage, upper and lower radiator hoses, alternator, radiator/shroud and intake manifold heater and waterpump hose.
6. Remove hood of car.
7. With a cherry picker or other lifting method, raise engine so that the passenger side lifts at more of an angle than the drivers side.
8. Once you have clearance, remove the bolt and drop the manifold down to clear the head.
9. Remove intake manifold and head.
10. Lift exhaust manifold out of the engine compartment.
I like the idea above about jacking on one of the pan bolts with a wood block spacer, however I am not sure if I could get the exhaust manifold out of the Darts engine compartment without also having the head off the engine.
Re: How to get 340 right side exhaust off? [Re: Menzaero] #150900
11/17/08 07:56 PM
11/17/08 07:56 PM
Thx for the replies. I was able to wiggle it off without moving the motor. I had to remove the rear studs. With these off, I was able to rotate the exhaust up toward the front of the car, and then wiggle the exhaust off that #2 stud.
It really doesn't need to be this hard. Seems like the studs are longer than necessary.
Re: How to get 340 right side exhaust off? [Re: BDW] #150901
11/17/08 08:44 PM
11/17/08 08:44 PM
Thx for the replies. it doesn't need to be this hard. Seems like the studs are longer than necessary.
are you ready for a set of tti's
Re: How to get 340 right side exhaust off? [Re: RapidRobert] #150902
11/17/08 11:47 PM
11/17/08 11:47 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
What I do on my car is remove passenger's side motor mount bolt, loosen driver's side motor mount bolt (don't remove bolt), then jack the motor up with a floor jack and wood under the oil pan. The passenger's side will rise allowing the manifold to come off.
