Re: How to get 340 right side exhaust off?
[Re: BDW]
#150887
11/14/08 03:59 PM
11/14/08 03:59 PM
RapidRobert
loosen the motor mounts (& whatever else needs to be loosened) & jack the front of the eng up just far enough to slide it out.
[Re: RapidRobert]
#150888
11/14/08 04:02 PM
11/14/08 04:02 PM
Posts: 4,998 North Pole,New York
formula_s
North Pole,New York
That looks like a b or e body looking at the shock tower.is the engine sitting center on the k frame. There should be enough clearance for it just slide off.
[Re: AARCONV]
#150895
11/16/08 10:04 PM
11/16/08 10:04 PM
Posts: 75,060 U.S.S.A.
JohnRR
U.S.S.A.
i thought studs are only on the outsides of the mani....
that spot uses the long nut , so it would be a stud also
[Re: mrpatel]
#150898
11/16/08 10:50 PM
11/16/08 10:50 PM
RapidRobert
I unbolt a 1/2 turn then go back the other way a skosh then unbolt another 1/2 turn like when you are cuttng threads with a tap. this has kept me from snapping many bolts/studs
