Re: How big of a tire on 69 b-body?
[Re: ProStDodge]
#1507929
09/26/13 08:18 PM
09/26/13 08:18 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
I know you can fit a 295/65/15 on a Dodge. 4.5 backspacing. 8" wheel. They look great and I will probably go with them on my Bee eventually...
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: rdrnr6970]
#1507933
09/28/13 04:54 PM
09/28/13 04:54 PM
Posts: 288 Birmingham, England
Mick70RR
Birmingham, England
I tried 315/50R15 on my 70 RR but they rubbed. Went back to 275/60R15 and they clear ok. Wheels are 10" with 5 1/2" backspace and the tyres are centred in the wheel well.
1970 Road Runner
505 cid
MCH CNC ported Stealth heads
MP 528 camshaft
4 speed
GV overdrive
11.98 @ 117 on street treads
[Re: Mick70RR]
#1507934
09/28/13 09:54 PM
09/28/13 09:54 PM
Posts: 11,502 delivering your oil
nutso suave
delivering your oil
i didn't think you could fit any tires that big under a b-body without modification...interesting. on a 68-70 plymouth b-body you can go with a 15" diameter, 10" wide wheel with a 275/60/15 tire? i have 15" diameter, 8" wide wheel with the same size tire. i wasn't sure of the backspacing, but it is good to know that 5 1/2" is good for a 10" wide wheel. what would be good backspacing for an 8" wheel? 4 1/2"? what is the proper backspacing for the front tires? i would like to put 15" diameter 7" wide wheel. i was hoping to use regular wheels in the front and reversed in the back, for a nostalgic look. front: rear: would 3 5/8" backspace be too much in the front on a 15" x 7" wheel?
[Re: ProStDodge]
#1507936
09/29/13 08:56 AM
09/29/13 08:56 AM
Posts: 15,995 RI Deep in the rust belt
chargervert
I have 295/50/15 tires on my 70 Charger,the rims are 15x10,with a 5 inch backspaceing. 68-70 Chargers have the biggest wheel wells of all the b bodies.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
[Re: Stanton]
#1507938
09/30/13 02:33 PM
09/30/13 02:33 PM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
You need 5-1/2 bs on a 10" rim
Disclaimer: b-body "Plymouth" ... Dodges seem to be able to have less bs.
https://board.moparts.org/ubbthreads/show...rue#Post7748848
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
