How big of a tire on 69 b-body? #1507926
09/26/13 02:30 PM
09/26/13 02:30 PM
Illinois, Indiana, Louisiana
ProStDodge Offline OP
I have a customer that wants to put a drag radial in a stock wheel well with a 15" rim.
We are looking at a M/T 325/50/15 on a 15x10 rim with a 4 1/2" backspacing.
Has anyone tried this with good results??
Scott
Re: How big of a tire on 69 b-body? [Re: ProStDodge] #1507927
09/26/13 03:55 PM
09/26/13 03:55 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You need 5-1/2 bs on a 10" rim
Disclaimer: b-body "Plymouth" ... Dodges seem to be able to have less bs.
Re: How big of a tire on 69 b-body? [Re: ProStDodge] #1507928
09/26/13 05:08 PM
09/26/13 05:08 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Plymouth or Dodge ? You can get more tire in a Dodge than a Plymouth.
Re: How big of a tire on 69 b-body? [Re: ProStDodge] #1507929
09/26/13 08:18 PM
09/26/13 08:18 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I know you can fit a 295/65/15 on a Dodge. 4.5 backspacing. 8" wheel. They look great and I will probably go with them on my Bee eventually...
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: How big of a tire on 69 b-body? [Re: OhioMopar] #1507930
09/27/13 09:13 AM
09/27/13 09:13 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Mine is a 70 not a 69 but these are 17x9.5 with 5.5 backspace. Tires are 275-60-17, 9 3/4" across the tread and 29.98 tall. That's as big as I can get in a Plymouth wheel well. There is also a 3/4" solid steel spacer in front of the leaf spring perch to push the rear back to add clearance at the front of the 1/4 panels.
...FAFO...
Re: How big of a tire on 69 b-body? [Re: skicker] #1507931
09/27/13 10:22 AM
09/27/13 10:22 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Yeah, '69 Plymouths will have the same issue at the front of the wheelwell. Without moving the axle or trimming the front lip the tallest tire that will fit is around 28".
Re: How big of a tire on 69 b-body? [Re: Stanton] #1507932
09/28/13 03:24 PM
09/28/13 03:24 PM
NJ
rdrnr6970 Offline
Your #1 source for current events
rdrnr6970  Offline
NJ
i had 50s on the rear of my 70 4spd roadrunner but what a hassel when u went to change em!
OWNER OF EVERYTHING FROM 1956 300 B,IMPERIAL,NEW YORKER HEMIS,AND NEW HEMI TRUCKS.....5TH GENRAMS.COM... 1969/70 ROADRUNNERS ,DARTS/CORONETS, NORTHEAST HEMI OWNERS ASSOCIATION.....WWW.PHANTASMCUDAS.COM....MOPAR FAMILY FOR 50 YEARS AND STILL GOING!MOPAR OWNER COAST TO COAST!!!!
Re: How big of a tire on 69 b-body? [Re: rdrnr6970] #1507933
09/28/13 04:54 PM
09/28/13 04:54 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
I tried 315/50R15 on my 70 RR but they rubbed. Went back to 275/60R15 and they clear ok. Wheels are 10" with 5 1/2" backspace and the tyres are centred in the wheel well.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: How big of a tire on 69 b-body? [Re: Mick70RR] #1507934
09/28/13 09:54 PM
09/28/13 09:54 PM
delivering your oil
nutso suave Offline
nutso suave  Offline
delivering your oil
i didn't think you could fit any tires that big under a b-body without modification...interesting.
on a 68-70 plymouth b-body you can go with a 15" diameter, 10" wide wheel with a 275/60/15 tire? i have 15" diameter, 8" wide wheel with the same size tire. i wasn't sure of the backspacing, but it is good to know that 5 1/2" is good for a 10" wide wheel. what would be good backspacing for an 8" wheel? 4 1/2"?
what is the proper backspacing for the front tires? i would like to put 15" diameter 7" wide wheel. i was hoping to use regular wheels in the front and reversed in the back, for a nostalgic look.
front:
rear:
would 3 5/8" backspace be too much in the front on a 15" x 7" wheel?
Re: How big of a tire on 69 b-body? [Re: ProStDodge] #1507935
09/29/13 01:24 AM
09/29/13 01:24 AM
Thanks everyone - With a little nudge, he has decided on a 275/60/15 on a 15x8 rim with 4.5" backspacing!
Re: How big of a tire on 69 b-body? [Re: ProStDodge] #1507936
09/29/13 08:56 AM
09/29/13 08:56 AM
RI Deep in the rust belt
chargervert Offline
chargervert  Offline
I have 295/50/15 tires on my 70 Charger,the rims are 15x10,with a 5 inch backspaceing. 68-70 Chargers have the biggest wheel wells of all the b bodies.
70 Charger R/T SE 472 Hemi 70 Charger R/T convertible 70 Charger R/T V Code Sixpack 69 Charger R/T SE Sunroofcar 68 Charger 383 68 Charger 318 71 Charger R/T 70 Challenger convertible 71 Challenger convertible 71 Cuda 340 09 Challenger R/T Classic
Re: How big of a tire on 69 b-body? [Re: chargervert] #1507937
09/30/13 01:22 PM
09/30/13 01:22 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Same here. Hard to tell in the picture but there is some 295's under there.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: How big of a tire on 69 b-body? [Re: Stanton] #1507938
09/30/13 02:33 PM
09/30/13 02:33 PM
San Angelo, Texas, U.S.A.
1968RR Offline
1968RR  Offline
https://board.moparts.org/ubbthreads/show...rue#Post7748848
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: How big of a tire on 69 b-body? [Re: 1968RR] #1507939
09/30/13 03:04 PM
09/30/13 03:04 PM
delivering your oil
nutso suave Offline
nutso suave  Offline
delivering your oil
Thanks for the link. I am wondering whether to order my wheels and tires online and take my chances, or buy them at a distributor. It seems like a wise move to fit them first, to make sure there aren't any issues with rubbing.
295s in the rear would be awesome, I didn't know that some b-bodies had a different size wheel openings...
