413 cam lifter swap #1504535
09/19/13 04:41 PM
09/19/13 04:41 PM
Parsons (SouthEast) Kansas
funkyjbp Offline OP
mopar addict
funkyjbp  Offline OP
mopar addict
everyone, hate to be such a rookie! I've never messed with a 413 internally. It has the funky small end pushrods and lifters in it now. i want to put a comp cams XE268 cam and lifter combo in it (already have the set). can i simply sway out the funky pushrods and use a set of 440 ones? thanks, Jp in the land of Oz.
71 SWB, 413 77 SWB, 318 92 SWB, 5.2 magnum 79 Macho Short bed, 318 03 stratus coupe R/T too many others not on the road!
Re: 413 cam lifter swap [Re: funkyjbp] #1504536
09/19/13 04:50 PM
09/19/13 04:50 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Should be able too basically the same motor.
Re: 413 cam lifter swap [Re: funkyjbp] #1504537
09/19/13 05:02 PM
09/19/13 05:02 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Yes you can, same engine family.
Re: 413 cam lifter swap [Re: JohnRR] #1504538
09/19/13 05:42 PM
09/19/13 05:42 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree.Did a swap on a lot of them.My kids 52 300 is one.We ran Summits pushrods for a RB.Check your rockers close also.They have a habit of wallowing out.Rocky
Chrysler Firepower
Re: 413 cam lifter swap [Re: therocks] #1504539
09/19/13 06:55 PM
09/19/13 06:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You can run the small diameter pushrods if you want. But you cannot run the larger diameter ones with the smaller lifter setup.
To be honest, push rods are cheap enough that it's probably best to update to the later ones from a 440.
Don't be the exception.
