413 cam lifter swap
#1504535
09/19/13 04:41 PM
09/19/13 04:41 PM
Posts: 847 Parsons (SouthEast) Kansas
funkyjbp
mopar addict
mopar addict
everyone, hate to be such a rookie! I've never messed with a 413 internally. It has the funky small end pushrods and lifters in it now. i want to put a comp cams XE268 cam and lifter combo in it (already have the set). can i simply sway out the funky pushrods and use a set of 440 ones? thanks, Jp in the land of Oz.
71 SWB, 413
77 SWB, 318
92 SWB, 5.2 magnum
79 Macho Short bed, 318
03 stratus coupe R/T
too many others not on the road!
Re: 413 cam lifter swap
[Re: JohnRR]
#1504538
09/19/13 05:42 PM
09/19/13 05:42 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
I agree.Did a swap on a lot of them.My kids 52 300 is one.We ran Summits pushrods for a RB.Check your rockers close also.They have a habit of wallowing out.Rocky
Chrysler Firepower
[Re: therocks]
#1504539
09/19/13 06:55 PM
09/19/13 06:55 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
You can run the small diameter pushrods if you want. But you cannot run the larger diameter ones with the smaller lifter setup.
To be honest, push rods are cheap enough that it's probably best to update to the later ones from a 440.
