Oil restriction question #1499558
09/10/13 12:05 PM
09/10/13 12:05 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
How much in terms of HP and quicker rpm does restricting oil drainback in the lifter galley gain?
Yeah, it's got a smallblock.
Re: Oil restriction question [Re: 340B5] #1499559
09/11/13 05:02 PM
09/11/13 05:02 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Trying to figure out why you'd do this - to reduce windage? Would be neat if there's a way to direct the oil from the drain back holes and shield it from being affected by the crank vortex, but in general I'd think you would not want to restrict oil in the lifter galley. Whatever you can do to get it back downstairs to the bottom of the pan the quickest way possible would be what you want. What's the theory on restricting it?
Re: Oil restriction question [Re: 340B5] #1499560
09/11/13 08:35 PM
09/11/13 08:35 PM
AndyF Offline
AndyF  Offline
There is some power to be gained there but it isn't a ton. Probably single digits.
Re: Oil restriction question [Re: AndyF] #1499561
09/11/13 08:39 PM
09/11/13 08:39 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
....and with the thought of FRYING the valve springs ?... no thanks ..
Re: Oil restriction question [Re: AndyF] #1499562
09/11/13 10:59 PM
09/11/13 10:59 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
That's what I thought. I'd just as soon be happy knowing all the parts are getting oil. Maybee if the engine turned 9000rpm, carefull restriction might be worthwile.
Sixpack; yeah it's for windage.
MrFiberglass; I like lots of oil cooling the valvesprings too.
Re: Oil restriction question [Re: Sixpak] #1499563
09/11/13 11:09 PM
09/11/13 11:09 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Look at the BES engine masters late Hemi. It has tubes running down from the valley area into the pan. Very ingenius.
Doug
Re: Oil restriction question [Re: dvw] #1499564
09/12/13 09:09 AM
09/12/13 09:09 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
My W2 engine had this. The head work was already done. They were done by Wayne County and were full of epoxy around the pushrods and all with external drainbacks. The lifter galley was blocked with only the drainbacks at the front and rear.
Leon
