Oil restriction question
#1499558
09/10/13 12:05 PM
09/10/13 12:05 PM
Posts: 1,532 off the grid
340B5
off the grid
How much in terms of HP and quicker rpm does restricting oil drainback in the lifter galley gain?
Yeah, it's got a smallblock.
Re: Oil restriction question
[Re: AndyF]
#1499561
09/11/13 08:39 PM
09/11/13 08:39 PM
Posts: 30,431 Florida STAYcation
BeEtLeJuIcE !
The village idiot's idiot
Florida STAYcation
There is some power to be gained there but it isn't a ton. Probably single digits.
....and with the thought of FRYING the valve springs ?... no thanks ..
[Re: Sixpak]
#1499563
09/11/13 11:09 PM
09/11/13 11:09 PM
Posts: 9,843 MI, usa
dvw
MI, usa
Trying to figure out why you'd do this - to reduce windage? Would be neat if there's a way to direct the oil from the drain back holes and shield it from being affected by the crank vortex, but in general I'd think you would not want to restrict oil in the lifter galley. Whatever you can do to get it back downstairs to the bottom of the pan the quickest way possible would be what you want. What's the theory on restricting it?
Look at the BES engine masters late Hemi. It has tubes running down from the valley area into the pan. Very ingenius. Doug
[Re: dvw]
#1499564
09/12/13 09:09 AM
09/12/13 09:09 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
My W2 engine had this. The head work was already done. They were done by Wayne County and were full of epoxy around the pushrods and all with external drainbacks. The lifter galley was blocked with only the drainbacks at the front and rear.
Leon
