Anyone use MT front tires..... #1494786
09/02/13 04:25 AM
09/02/13 04:25 AM
Florida STAYcation
dOc … Offline OP
The village idiot's idiot
dOc …  Offline OP
Florida STAYcation
What kind of air pressures are recommended for these ?......just for the record mine are the 24x4.5x15 ....on 3.5 wheels .....but I don't think that matters....
Re: Anyone use MT front tires..... [Re: dOc …] #1494787
09/02/13 04:31 AM
09/02/13 04:31 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I run mine at 45 psi.
But then again I'm trying to support 2500# worth of nose weight as well.
29x4.5x15s if it matters.
Re: Anyone use MT front tires..... [Re: Duner] #1494788
09/02/13 04:35 AM
09/02/13 04:35 AM
Arizona
Chris'sBarracuda Offline
Arizona
40-42 same exact tire.
But the car weighs right at 3000#..
Chris..
Re: Anyone use MT front tires..... [Re: dOc …] #1494789
09/02/13 10:14 AM
09/02/13 10:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I run anywhere from 35# to 45# in the same tire..
lower pressure if I want to slow my RT down
Re: Anyone use MT front tires..... [Re: dOc …] #1494790
09/02/13 03:27 PM
09/02/13 03:27 PM
Az
Crizila Offline
Crizila  Offline
Az
I run them - 28X7.50 - 15's on 6" wheels. I have a heavy car and I like their 1100 lb load rating. Run them at 32psi. BTW, that 1100 lb load rating is at 30psi. - and it does matter how much air you put in them.
Fastest 300
Re: Anyone use MT front tires..... [Re: dOc …] #1494791
09/02/13 03:42 PM
09/02/13 03:42 PM
It depends on which front M/T tire your talking about If ET fronts, I don't exceed the suggest pressures, I have ran less My current car came with radial( I think )M/T Sportsman fronts, a lot more pressure in them
Re: Anyone use MT front tires..... [Re: dOc …] #1494792
09/02/13 08:34 PM
09/02/13 08:34 PM
Why would you run that tall of tire on your lawn mower. I only have 22.5x4.5 on mine.
One leaks down over 3 to 4 weeks, other one doesn't loose any air. I keep them at 35-40 psi.
Re: Anyone use MT front tires..... [Re: ] #1494793
09/04/13 03:01 AM
09/04/13 03:01 AM
Florida STAYcation
dOc … Offline OP
dOc …  Offline OP
Florida STAYcation
No lawns for me double B ....but my ride now rivals 180 diff from that boat you have.....you use limo tires in that ?... The tires I speak of here are on that Laser I picked up. According to the last owner there were no psi specs on the tires anywhere ....and I have not looked .....too busy with other stuff. Thx for the input .....and may I add to this ....how about the sportsman pro dot tires? ......waste of time and money ?
Re: Anyone use MT front tires..... [Re: dOc …] #1494794
09/04/13 01:56 PM
09/04/13 01:56 PM
I think the M/T ET front bieas plys call for no more then 32 or 36 lbs, it is on the side on the mounting and load raing instructions in very small print On the M/T Sportsman fronts radials I haven't looked at them yet ,but I'm sure it is on them also
Re: Anyone use MT front tires..... [Re: Cab_Burge] #1494795
09/04/13 05:06 PM
09/04/13 05:06 PM
Az
Crizila Offline
Crizila  Offline
Az
1100 lbs @ 30 psi - - my previous post.
Fastest 300
Re: Anyone use MT front tires..... [Re: dOc …] #1494796
09/04/13 05:50 PM
09/04/13 05:50 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I have a pair of M/T Radial S/R's on the Bee. Haven't put any miles or tested any tire pressures yet. II'll keep you posted!
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Anyone use MT front tires..... [Re: OhioMopar] #1494797
09/04/13 09:51 PM
09/04/13 09:51 PM
sg66mopar Offline
sg66mopar  Offline
I have the 22.5s (ET Fronts) on mine right now. I've run every small front tire made and always at 40-50 PSI to keep the rollout as short as possible. The current MTs have been on the car about 5 years.
