Anyone use MT front tires..... #1494786
09/02/13 04:25 AM
09/02/13 04:25 AM
Florida STAYcation
dOoC Offline OP
The village idiot's idiot
dOoC  Offline OP
Florida STAYcation
What kind of air pressures are recommended for these ?......just for the record mine are the 24x4.5x15 ....on 3.5 wheels .....but I don't think that matters....
Re: Anyone use MT front tires..... [Re: dOoC] #1494787
09/02/13 04:31 AM
09/02/13 04:31 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I run mine at 45 psi.
But then again I'm trying to support 2500# worth of nose weight as well.
29x4.5x15s if it matters.
Re: Anyone use MT front tires..... [Re: Duner] #1494788
09/02/13 04:35 AM
09/02/13 04:35 AM
Arizona
Chris'sBarracuda Offline
Arizona
40-42 same exact tire.
But the car weighs right at 3000#..
Chris..
Re: Anyone use MT front tires..... [Re: dOoC] #1494789
09/02/13 10:14 AM
09/02/13 10:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I run anywhere from 35# to 45# in the same tire..
lower pressure if I want to slow my RT down
Re: Anyone use MT front tires..... [Re: dOoC] #1494790
09/02/13 03:27 PM
09/02/13 03:27 PM
Az
Crizila Offline
Crizila  Offline
Az
I run them - 28X7.50 - 15's on 6" wheels. I have a heavy car and I like their 1100 lb load rating. Run them at 32psi. BTW, that 1100 lb load rating is at 30psi. - and it does matter how much air you put in them.
Fastest 300
Re: Anyone use MT front tires..... [Re: dOoC] #1494791
09/02/13 03:42 PM
09/02/13 03:42 PM
It depends on which front M/T tire your talking about If ET fronts, I don't exceed the suggest pressures, I have ran less My current car came with radial( I think )M/T Sportsman fronts, a lot more pressure in them
Re: Anyone use MT front tires..... [Re: dOoC] #1494792
09/02/13 08:34 PM
09/02/13 08:34 PM
Why would you run that tall of tire on your lawn mower. I only have 22.5x4.5 on mine.
One leaks down over 3 to 4 weeks, other one doesn't loose any air. I keep them at 35-40 psi.
Re: Anyone use MT front tires..... [Re: ] #1494793
09/04/13 03:01 AM
09/04/13 03:01 AM
Florida STAYcation
dOoC Offline OP
dOoC  Offline OP
Florida STAYcation
No lawns for me double B ....but my ride now rivals 180 diff from that boat you have.....you use limo tires in that ?... The tires I speak of here are on that Laser I picked up. According to the last owner there were no psi specs on the tires anywhere ....and I have not looked .....too busy with other stuff. Thx for the input .....and may I add to this ....how about the sportsman pro dot tires? ......waste of time and money ?
Re: Anyone use MT front tires..... [Re: dOoC] #1494794
09/04/13 01:56 PM
09/04/13 01:56 PM
I think the M/T ET front bieas plys call for no more then 32 or 36 lbs, it is on the side on the mounting and load raing instructions in very small print On the M/T Sportsman fronts radials I haven't looked at them yet ,but I'm sure it is on them also
Re: Anyone use MT front tires..... [Re: Cab_Burge] #1494795
09/04/13 05:06 PM
09/04/13 05:06 PM
Az
Crizila Offline
Crizila  Offline
Az
1100 lbs @ 30 psi - - my previous post.
Fastest 300
Re: Anyone use MT front tires..... [Re: dOoC] #1494796
09/04/13 05:50 PM
09/04/13 05:50 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I have a pair of M/T Radial S/R's on the Bee. Haven't put any miles or tested any tire pressures yet. II'll keep you posted!
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Anyone use MT front tires..... [Re: OhioMopar] #1494797
09/04/13 09:51 PM
09/04/13 09:51 PM
sg66mopar Offline
sg66mopar  Offline
I have the 22.5s (ET Fronts) on mine right now. I've run every small front tire made and always at 40-50 PSI to keep the rollout as short as possible. The current MTs have been on the car about 5 years.
