Re: Anyone use MT front tires.....
[Re: IcorkSOAK]
#1494790
09/02/13 03:27 PM
09/02/13 03:27 PM
Posts: 7,506 Az
Crizila
Az
I run them - 28X7.50 - 15's on 6" wheels. I have a heavy car and I like their 1100 lb load rating. Run them at 32psi. BTW, that 1100 lb load rating is at 30psi. - and it does matter how much air you put in them.
Fastest 300
[Re: IcorkSOAK]
#1494792
09/02/13 08:34 PM
09/02/13 08:34 PM
What kind of air pressures are recommended for these ?......just for the record mine are the 24x4.5x15 ....on 3.5 wheels .....but I don't think that matters....
Why would you run that tall of tire on your lawn mower. I only have 22.5x4.5 on mine.
One leaks down over 3 to 4 weeks, other one doesn't loose any air. I keep them at 35-40 psi.
[Re: IcorkSOAK]
#1494794
09/04/13 01:56 PM
09/04/13 01:56 PM
Posts: 43,719 Bend,OR USA
Cab_Burge
I think the M/T ET front bieas plys call for no more then 32 or 36 lbs, it is on the side on the mounting and load raing instructions in very small print On the M/T Sportsman fronts radials I haven't looked at them yet ,but I'm sure it is on them also
[Re: IcorkSOAK]
#1494796
09/04/13 05:50 PM
09/04/13 05:50 PM
Posts: 8,793 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
I have a pair of M/T Radial S/R's on the Bee. Haven't put any miles or tested any tire pressures yet. II'll keep you posted!
1969 Dart GTS 340 1969 Coronet R/T X9 N-96 1999 Dodge Dakota R/T RC 2015 Dodge Dart GT 2019 Ram 2500 Big Horn
[Re: OhioMopar]
#1494797
09/04/13 09:51 PM
09/04/13 09:51 PM
Posts: 1,288 Oregon
sg66mopar
I have the 22.5s (ET Fronts) on mine right now. I've run every small front tire made and always at 40-50 PSI to keep the rollout as short as possible. The current MTs have been on the car about 5 years.
