C E Rear Shocks #1492684
08/29/13 08:05 PM
08/29/13 08:05 PM
ont,canada
mopartuner Offline OP
ont,canada
I have the 3 way adj rear shocks on my car and was just wanting to know what diference can the adjustment make?The shock when it extends is not adjustable is it?These ones were set to as firm as they go many years ago and I was just thinking if it may help the 60ft time to adjust them?These shocks feel like they extend easy but are firm to compress.
410 pump gas solis flat tappet cam 10.95 so far
Re: C E Rear Shocks [Re: mopartuner] #1492685
08/29/13 08:14 PM
08/29/13 08:14 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Want another set,,,???,,,I'll send you a set...for FREE!! I couldn't get them to work on my car at all. Bought AFCO double adjustable,,much better.
If you like drag racing, support your local track.
Re: C E Rear Shocks [Re: CHAPPER] #1492686
08/29/13 08:57 PM
08/29/13 08:57 PM
Way out in the sticks of Weste...
DusterDog Offline
DusterDog  Offline
I'll take 'em!!!!!
I can even pick them up at Norwalk, if you're going!!
"I've upped my horsepower, so...... UP YOURS!!!"
Re: C E Rear Shocks [Re: DusterDog] #1492687
08/29/13 09:56 PM
08/29/13 09:56 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
got rid of mine too......junk !
Re: C E Rear Shocks [Re: mopartuner] #1492688
08/29/13 10:26 PM
08/29/13 10:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you cant control the extension rate they are useless
Re: C E Rear Shocks [Re: MR_P_BODY] #1492689
08/29/13 10:56 PM
08/29/13 10:56 PM
ont,canada
ont,canada
I am going to do the cal-tracs over the winter just trying to get what I can outta this junk for now.
Re: C E Rear Shocks [Re: mopartuner] #1492690
08/30/13 01:46 AM
08/30/13 01:46 AM
long island newyork
Abodyjohn88 Offline
Abodyjohn88  Offline
long island newyork
I have my ce 3 way rears set to 50/50 and they seem to work decent on a 12 second street car
Re: C E Rear Shocks [Re: Abodyjohn88] #1492691
08/30/13 01:55 AM
08/30/13 01:55 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
50/50 here too on a 10 sec car
Re: C E Rear Shocks [Re: rebel] #1492692
08/30/13 06:42 AM
08/30/13 06:42 AM
Stockholm, Sweden
MrSixpack Offline
MrSixpack  Offline
Stockholm, Sweden
Afco is the way to go.
Just my
1970 Super Stock Challenger ex. Paul Rossi
1968 Dodge Dart GT 340
1968 Dodge Charger /6 3 speed manual
1966 Chrysler 300 Loaded
1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: C E Rear Shocks [Re: mopartuner] #1492693
08/30/13 08:37 AM
08/30/13 08:37 AM
Seminole County FL to Plymouth...
Barry70GTX Offline
Barry70GTX  Offline
Our Rear Drag Shocks are also adjustable in three ratios: 30/70, 40/60 and 50/50. These ratios also represent the percentage of force required to compress and extend the shock unit. Only this time the first number is compression and the second extension. These shocks also adjust by compressing them fully and rotating to the desired setting on the body.
It looks like you may not have them set at 50/50.
NMCA NSS 67 Coronet
Re: C E Rear Shocks [Re: Barry70GTX] #1492694
08/30/13 11:27 AM
08/30/13 11:27 AM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Had CE 3 ways all around on my 9 secDuster. Thought they worked great, very consistant.
Mine worked best with left rear loosest, and right rear stiffest, with 002/003 leafs, fronts at 90/10. Later changed to 80/20, which helped control wheelstands better
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: C E Rear Shocks [Re: Barry70GTX] #1492695
08/30/13 07:25 PM
08/30/13 07:25 PM
ont,canada
ont,canada
Thanks,I am going to take them off and check them
