C E Rear Shocks
#1492684
08/29/13 08:05 PM
08/29/13 08:05 PM
Posts: 614 ont,canada
mopartuner
ont,canada
I have the 3 way adj rear shocks on my car and was just wanting to know what diference can the adjustment make?The shock when it extends is not adjustable is it?These ones were set to as firm as they go many years ago and I was just thinking if it may help the 60ft time to adjust them?These shocks feel like they extend easy but are firm to compress.
410 pump gas solis flat tappet cam 10.95 so far
Re: C E Rear Shocks
[Re: mopartuner]
#1492685
08/29/13 08:14 PM
08/29/13 08:14 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
Want another set,,,???,,,I'll send you a set...for FREE!! I couldn't get them to work on my car at all. Bought AFCO double adjustable,,much better.
If you like drag racing, support your local track.
Re: C E Rear Shocks
[Re: mopartuner]
#1492688
08/29/13 10:26 PM
08/29/13 10:26 PM
Posts: 52,972 Romeo MI
MR_P_BODY
If you cant control the extension rate they are useless
Re: C E Rear Shocks
[Re: MR_P_BODY]
#1492689
08/29/13 10:56 PM
08/29/13 10:56 PM
mopartuner
ont,canada
I am going to do the cal-tracs over the winter just trying to get what I can outta this junk for now.
Re: C E Rear Shocks
[Re: rebel]
#1492692
08/30/13 06:42 AM
08/30/13 06:42 AM
Posts: 952 Stockholm, Sweden
MrSixpack
Stockholm, Sweden
Afco is the way to go. Just my
1970 Super Stock Challenger ex. Paul Rossi 1968 Dodge Dart GT 340 1968 Dodge Charger /6 3 speed manual 1966 Chrysler 300 Loaded 1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: C E Rear Shocks
[Re: mopartuner]
#1492693
08/30/13 08:37 AM
08/30/13 08:37 AM
Posts: 721 Seminole County FL to Plymouth...
Barry70GTX
Our Rear Drag Shocks are also adjustable in three ratios: 30/70, 40/60 and 50/50. These ratios also represent the percentage of force required to compress and extend the shock unit. Only this time the first number is compression and the second extension. These shocks also adjust by compressing them fully and rotating to the desired setting on the body.
It looks like you may not have them set at 50/50.
NMCA NSS 67 Coronet
Re: C E Rear Shocks
[Re: Barry70GTX]
#1492694
08/30/13 11:27 AM
08/30/13 11:27 AM
Posts: 11,713 Portage,michigan
B3422W5
Portage,michigan
Had CE 3 ways all around on my 9 secDuster. Thought they worked great, very consistant. Mine worked best with left rear loosest, and right rear stiffest, with 002/003 leafs, fronts at 90/10. Later changed to 80/20, which helped control wheelstands better
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
