Evaporative leak on 2000 Ram.Any Dodge techs out there? #1492457
08/29/13 03:05 PM
08/29/13 03:05 PM
South San Francisco, Ca
70sixpkrt Offline OP
Last month my engine light came on my 2000 Dodge Ram 5.9. Brought it to my local mechanic and he said it was a vapor leak from a hose to the vapor canister and a leak detection pump code P0455 so he fixed the hose and changed the pump. 4 days later the light came back on so I decided to bring it to the dealership since my mechanic had a death in the family. The dealership said it was the vapor canister and Duty Purge Pump per TSB code P0455 so they replaced all the lines and vapor canister and also reflashed the PCM and resmoked the entire system. No leaks. The next day he tested everything again it passed with no codes. Just to make sure he retested it and the test never completed this time. They contacted STAR and updated PCM and retested and test never finished. Contacted STAR again and they said it could be possible software issue. So the leak detection pump, Duty Purge Pump, hose and vapor canister all have been replaced. 3 days later (this morning) engine light on again. I am getting frustrated with this thing. Does it sound like my PCM is going bad? Any Dodge techs out there?
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Evaporative leak on 2000 Ram.Any Dodge techs out there? [Re: 70sixpkrt] #1492458
08/29/13 03:17 PM
08/29/13 03:17 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I think a bad gas cap can cause a evap code.
Re: Evaporative leak on 2000 Ram.Any Dodge techs out there? [Re: 70sixpkrt] #1492459
08/29/13 04:14 PM
08/29/13 04:14 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
New gas cap fixed that on my '98 Ram. Smearing the rubber seal on the cap with Vaseline fixed it for a while but not long.
Re: Evaporative leak on 2000 Ram.Any Dodge techs out there? [Re: John_Kunkel] #1492460
08/29/13 04:18 PM
08/29/13 04:18 PM
New gas cap was replaced with Vaseline. Pcv valve also replaced. Leak detection pump was replaced twice. All parts replaced with factory Mopar parts.
4-speed
3:54 Dana
Re: Evaporative leak on 2000 Ram.Any Dodge techs out there? [Re: 70sixpkrt] #1492461
08/29/13 10:07 PM
08/29/13 10:07 PM
Well the dealership is telling me that it is my engine harness which has been discontinued. Anybody know where I can get one?
4-speed
3:54 Dana
Re: Evaporative leak on 2000 Ram.Any Dodge techs out there? [Re: 70sixpkrt] #1492462
08/29/13 10:33 PM
08/29/13 10:33 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Sounds to me like the dealership is throwing parts at a problem they are guessing at. What is so wrong with the harness that they can't repair the wiring?
Re: Evaporative leak on 2000 Ram.Any Dodge techs out there? [Re: stumpy] #1492463
08/29/13 10:49 PM
08/29/13 10:49 PM
They sad they can wiggle the harness and the engine light will go on and off. I am going there tomorrow to see it. So far 2 different mechanics said that is a possibility since I have replacied everything that pertains to the evaporative system.
4-speed
3:54 Dana
Re: Evaporative leak on 2000 Ram.Any Dodge techs out there? [Re: 70sixpkrt] #1492464
08/29/13 11:22 PM
08/29/13 11:22 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I think I'd trace the harness while wriggling it in short sections until I located the problem.
Re: Evaporative leak on 2000 Ram.Any Dodge techs out there? [Re: stumpy] #1492465
08/29/13 11:41 PM
08/29/13 11:41 PM
To me it sounds like they don't want to spend the time and do that.
4-speed
3:54 Dana
Re: Evaporative leak on 2000 Ram.Any Dodge techs out there? [Re: 70sixpkrt] #1492466
08/30/13 03:05 PM
08/30/13 03:05 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Does this dealership have an know how to use a smoke machine? It really is the best/only way to identify Evap leaks. As for having a bad harness, well this is an electrical system and we always explain that to our customers. It can always be a mechanical or electrical issue. Not sure it would need an entire new harness, other than it will save labor hours to replace it all rather than isolate the issue and repair it. My suggestion is find a better place to take your truck to for repairs. Dealerships want easy profitable repairs, not necessarily the time consuming diagnostic and electrical repair stuff. BTW the wiggle test is pretty common diagnostic approach these days. You would be surprised how often it works.
Oh yeah FWIW the last one we had actually had a crack in a rubber grommet that was the issue. The evap line had a rubber connection from the one of the plastic lines that had dried out and cracked. We found it with a smoke machine. After it had been to a shop without one that just kept throwing parts at it. A lot of shop tend the throw parts at evap leaks because they don't want to invest in a smoke machine.
Re: Evaporative leak on 2000 Ram.Any Dodge techs out there? [Re: Al_Alguire] #1492467
08/30/13 05:38 PM
08/30/13 05:38 PM
A smoke test was done numerous times. The first time they did that they found a leak from a line going to the vapor canister. Fixed that. Did more numerous smoke test and nothing. They ended up checking the harness. They wiggled the harness and load tested ckt k52 and f12. They did some other tests and found high resistance (open circuit) when wiggled at circuit k52.
4-speed
3:54 Dana
Re: Evaporative leak on 2000 Ram.Any Dodge techs out there? [Re: 70sixpkrt] #1492468
08/30/13 08:17 PM
08/30/13 08:17 PM
pennsylvania
poboyengineering Offline
pennsylvania
wiggling the wires and getting a failure means you have a bad connection or a broken wire. corrosion/fretting/failed crimp, etc...shouldn't be too hard to find. I don't have an FSM handy...what do these circuits control?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Evaporative leak on 2000 Ram.Any Dodge techs out there? [Re: poboyengineering] #1492469
08/31/13 12:50 PM
08/31/13 12:50 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Corossion and broken wires are common especially here.I dont know how many GM headlights Ive fixed because of crappy soldered connections in the front.I guess they figure it was good enough to get out of warranty so why worry about it.Last front harness I did on a Sunfire cost was almost 600 bucks.Plus mark up and labor.Rocky
Chrysler Firepower
Re: Evaporative leak on 2000 Ram.Any Dodge techs out there? [Re: therocks] #1492470
09/05/13 10:41 PM
09/05/13 10:41 PM
Code P0443. Still battling the problem. I got a tune up 3-4 weeks before this whole fiasco. Can a tune up cause this?
4-speed
3:54 Dana
Re: Evaporative leak on 2000 Ram.Any Dodge techs out there? [Re: 70sixpkrt] #1492471
09/06/13 10:31 PM
09/06/13 10:31 PM
Marilla, New York
RalleyA12 Offline
RalleyA12  Offline
Marilla, New York
Had this problem with a truck I owned, the plastic around the fuel pump was cracked. Being on top of the fuel tank you couldn't see any smoke until you dropped the tank.
Re: Evaporative leak on 2000 Ram.Any Dodge techs out there? [Re: RalleyA12] #1492472
09/06/13 11:52 PM
09/06/13 11:52 PM
fredericksburg virginia
mopwrd340 Offline
mopwrd340  Offline
This is a common problem with mopars of that era i had a 03 chrysler t/c and my son had a 02 durango that would come up with evap codes all the time . i got the van thru emissions barely by my sons friend worked at a place that did emissions and got it to pass . but from what i heard the plastic hoses and nipples crack on the fuel pump module .
Re: Evaporative leak on 2000 Ram.Any Dodge techs out there? [Re: 70sixpkrt] #1492473
09/07/13 12:09 AM
09/07/13 12:09 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Total and complete bullsh!t story. Typical dealership. A check engine light will only go off when the proper erase procedure is done.
Find another fuel station: 9 times out of ten switching fuel will give a check engine light. You are getting stale fuel from somewhere.
By the way, emissions may be covered for lifetime on this truck. Check with 1-800 Dodge to confirm. None of this should be costing you a cent.
Mo' Farts
Moderated by "tbagger".
Re: Evaporative leak on 2000 Ram.Any Dodge techs out there? [Re: Grizzly] #1492474
09/07/13 03:05 AM
09/07/13 03:05 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
P0443 is a CIRCUIT prob... not an evap system prob..... but keep trying those different gas stations!
Re: Evaporative leak on 2000 Ram.Any Dodge techs out there? [Re: J_BODY] #1492475
09/07/13 01:07 PM
09/07/13 01:07 PM
I'm dropping off my truck to my mechanic (not dealership) on Monday. He is also stumped. The dealership sounds like they are done with me. They said it is in the wiring harness and too time consuming.
4-speed
3:54 Dana
Re: Evaporative leak on 2000 Ram.Any Dodge techs out there? [Re: 70sixpkrt] #1492476
09/07/13 01:38 PM
09/07/13 01:38 PM
N
NITROUSN Offline
NITROUSN  Offline
N
No doubt it will take some time to find the problem. The code you have now is not the same as you started with. So it sounds to me like the original problem is fixed and now you have another problem. The fix only take 5 minutes to correct. The problem is most people don't want to pay for the time to get to the root cause. Its obvious they have isolated the bad circuit. You have to commit to the time it may take to get to the gremlin.
In our shops its straight time on these problems. And when the customer tells me about all the hands that have already tried to fix it I inform them it may even take more time. Most often these problems have several causes. The original root cause and all the others from people working on it that have no business or smarts to comprehend the correct repair procedure.
