GOING DEEP #1492212
08/29/13 01:13 AM
08/29/13 01:13 AM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
how deep are you guys going.
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: GOING DEEP [Re: WHITEDART] #1492213
08/29/13 01:18 AM
08/29/13 01:18 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
as in staging?
Re: GOING DEEP [Re: rebel] #1492214
08/29/13 02:40 AM
08/29/13 02:40 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Unfortunately with all I got
As for staging I am as shallow as possible. Only way to KNOW where you are in the beams each time. Stage as shallow as possible and adjust from there to get the R/T's you are after.
Again unforunately those two tales are very similar
Re: GOING DEEP [Re: Al_Alguire] #1492215
08/29/13 06:39 AM
08/29/13 06:39 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Like Al said I like to go very shallow too but we have a couple dragsters at PRP doing something that is kinda stirring the pot some. Door cars are always held in the box while a dragster burn and coast thru the line. We are then told to start our procedure as the dragster backs up. Well they are slowly backing thru the second staging bulb and just backing till the second stage bulb turn off. The second a door car lights the first bulb they quickly roll the one inch into full stage. By staging rules its legal as they are going forward the last 1 inch. The procedure kinda rushes the door car to roll in a little quicker than they planned to. Legal yes, but when I race these dragsters in the near future the tables will be turned some. One of the racers is a member here now in a chevy powered dragster. As a racer I lost respect for HER.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: GOING DEEP [Re: pittsburghracer] #1492216
08/29/13 07:11 AM
08/29/13 07:11 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
depends on the tree. on a Pro tree .400 i go in deep, turn the top light out. on a Full tree .400 i'm shallow, stage on, minuteist creep & hold the button.
Re: GOING DEEP [Re: rebel] #1492217
08/29/13 08:46 AM
08/29/13 08:46 AM
Mooresburg, Tn
'72CudaRacer Online content
'72CudaRacer  Online Content
Mooresburg, Tn
I stage a little different than most. I footbrake (true footbrake, no transbrake, no 2-step) and even though my car is very consistant, it reacts slow. If I just barely dink the 2nd light on and leave on the bottom amber bulb, my reaction time is in the .09 range. If I actually go full deep (turn off the pre stage bulb), after a few passes I get comfortable with deep staging, and I'm -.006 red. My solution is to go 1/2 deep, meaning turn on the 2nd bulb and then roll in just a bit more, but leave the pre stage light lit. A lot of old timers call this method "bump racing". Most will tell you that it is difficult at best to be sucsessful at, and I will tell you that it takes a lot of practice to get it right every time. When you race like this, you have to be mindful of your dial in also because where you stage will effect your ET. In my case there is .010 sec difference between shallow staged and full deep staged. It might not be for everyone, but, it works for me.
If you are in the lane beside me and you see my top amber flicker then stay lit, you're gonna need your "A" game, 'cause the old man is probably gonna drill you!
Brian
Re: GOING DEEP [Re: '72CudaRacer] #1492218
08/29/13 08:55 AM
08/29/13 08:55 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I stage as shallow as possible on the standard .500
tree
but roll in deep on the .400 pro... my car reacts super
fast
Re: GOING DEEP [Re: Al_Alguire] #1492219
08/29/13 12:23 PM
08/29/13 12:23 PM
Cheswick, PA
Bob_Spelic Offline
Bob_Spelic  Offline
Cheswick, PA
I like to go in as shallow as possible.
John, In my dragster, I was taught by a good racer to use the slow backup procedure and just turn the lights on and then back off while backing up very slowly. Sitting there with no lights on it doesn’t take much movement to turn on the top bulb and makes staging the long dragsters much easier. At least I though so.
From what you wrote, I take it the racer in question is backing up and cycles the lower bulb and then sits there and leaves the top bulb on; and driving right into stage when the opponent turns on their top bulb. As you said nothing illegal there, but certainly causes a rush for the opponent.
Bob Spleic
Re: GOING DEEP [Re: Bob_Spelic] #1492220
08/29/13 12:32 PM
08/29/13 12:32 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Bob Spleic
I know that MOST dragsters run a glide but if you
do that with a 727 you will blow the sprag... you need
ABOUT 4' in the forward motion to make sure the sprag
is set
Re: GOING DEEP [Re: MR_P_BODY] #1492221
08/29/13 12:47 PM
08/29/13 12:47 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
I have seen a certain racer at Norwalk always go through the lights and then he backs up slow. Gets the top bulb on and waits for the other car to stage. Then he backs into the 2nd light very slow and then puts in in forward gear. He is running a glide. I do not like to see it but no one has ever stopped him from doing it. It is a door car too.
I stage as shallow as possible......
Russ
Re: GOING DEEP [Re: Al_Alguire] #1492222
08/29/13 12:53 PM
08/29/13 12:53 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
As for staging...
You're killin' me, Al!
Re: GOING DEEP [Re: Bob_Spelic] #1492223
08/29/13 01:02 PM
08/29/13 01:02 PM
PA.
"Little"John
"Little"John
PA.
Bob Spleic
Yes this is what they are doing. Both lights are never off.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: GOING DEEP [Re: pittsburghracer] #1492224
08/29/13 03:45 PM
08/29/13 03:45 PM
Mooresburg, Tn
Mooresburg, Tn
Bob Spleic
I deal with that also, but most of the racers that do it are slower than me, leaving first. Before I ever turn a light on, I make sure I am ready to go(and depending on who it is, it could take a while ), then when I turn my top light on, they go in and I still got approx 7-10 seconds to get in. I pretty much treat them like someone that double bulbed me. Let'm sit there and stare at that tree. Wanna look way from it? I dare you. Want to play games? OK with me.
Brian
Re: GOING DEEP [Re: '72CudaRacer] #1492225
08/29/13 04:07 PM
08/29/13 04:07 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Bob Spleic
Brian
One Attaboy for you 10 sec is an eternity.
Ebbabody got time fo dat.
Yeah, it's got a smallblock.
Re: GOING DEEP [Re: 340B5] #1492226
08/29/13 04:23 PM
08/29/13 04:23 PM
PA.
"Little"John
"Little"John
PA.
Bob Spleic
Brian
The holding back on the staging plays into their hand and the wrong way to go about it for me. I'm on pump gas and most of them are on alcohol. In a week or to I will be too so it may change my thinking. The carb for my Duster went out this week for the change-over to alcohol and will be going on soon. The Daytona will be sporting a toilet when it returns.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
