Valve Spring Replacement Tool? #1491464
08/27/13 07:33 AM
08/27/13 07:33 AM
Indiana
Y
YO7_A66 Offline OP
YO7_A66  Offline OP
Y
Indiana
I may invest in a valve spring replacement tool. I would like one that can replace the springs with the engine(340:shaft mount)in the car. What do you recommend? I have seen some from $50 all the way up to $300. I want one that is safe and durable.
I found the attached on the Mancini websight. Is it a decent one to use?
Thank you.
Re: Valve Spring Replacement Tool? [Re: YO7_A66] #1491465
08/27/13 08:14 AM
08/27/13 08:14 AM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
I have the small block version of that tool. I like it.
Only shortcoming might be when working with beehive springs and their smaller retainers. It works, but it doesn't hold the retainer very securely.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Valve Spring Replacement Tool? [Re: 471Magnum] #1491466
08/27/13 12:17 PM
08/27/13 12:17 PM
AndyF Offline
AndyF  Offline
Take an old spring cup and flip it over to use it on top of the retainer.
Re: Valve Spring Replacement Tool? [Re: AndyF] #1491467
08/27/13 02:59 PM
08/27/13 02:59 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
For about $5 in materials, I made this:
Re: Valve Spring Replacement Tool? [Re: Kern Dog] #1491468
08/27/13 03:02 PM
08/27/13 03:02 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I wanted to paint it with a high visibility color. Later I realized it was Harbor Freight orange.
Re: Valve Spring Replacement Tool? [Re: Kern Dog] #1491469
08/27/13 04:55 PM
08/27/13 04:55 PM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Well played frankenduster.
I can't afford this. mark
Re: Valve Spring Replacement Tool? [Re: a12superbee] #1491470
08/27/13 07:18 PM
08/27/13 07:18 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
This is the best tool I have used. It works on the bigblock with shaft mounted rockers so it should work fine on the smallblock. I like the fact that you run the allen screw down and can use both hands to remove the spring as you dont have to hold the tool with one hand. Bought this at Mancini. Its not real cheap but it works great. Ron
Re: Valve Spring Replacement Tool? [Re: 383man] #1491471
08/27/13 10:07 PM
08/27/13 10:07 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I like that one Ron has. My triceps were sore after changing my springs!
Re: Valve Spring Replacement Tool? [Re: Kern Dog] #1491472
08/28/13 09:46 AM
08/28/13 09:46 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
The problem with all of them is I can't fit my big fingers in to get at the keepers. I modified mine for more clearance and now it bends. Oh well, got he job done. Never again!
Re: Valve Spring Replacement Tool? [Re: babarracuda] #1491473
08/28/13 02:18 PM
08/28/13 02:18 PM
AndyF Offline
AndyF  Offline
Use a magnetic pick up tool. Looks like a pen but has a magnet on the end. Just reach in there and the valve locks pop out and stick to the magnet.
Re: Valve Spring Replacement Tool? [Re: AndyF] #1491474
08/29/13 12:59 AM
08/29/13 12:59 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
And a small screwdriver with grease on the tip to insert the keepers. The one 383man uses is no longer available from Mancini. They couldn't sell it for what it costs to make (they are looking into it). I think AndyF should start making them.... It works great when you have 750 lbs open pressure
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
