Valve Spring Replacement Tool?
#1491464
08/27/13 07:33 AM
08/27/13 07:33 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
I may invest in a valve spring replacement tool. I would like one that can replace the springs with the engine(340:shaft mount)in the car. What do you recommend? I have seen some from $50 all the way up to $300. I want one that is safe and durable. I found the attached on the Mancini websight. Is it a decent one to use? Thank you.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: Valve Spring Replacement Tool?
[Re: YO7_A66]
#1491465
08/27/13 08:14 AM
08/27/13 08:14 AM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
I have the small block version of that tool. I like it.
Only shortcoming might be when working with beehive springs and their smaller retainers. It works, but it doesn't hold the retainer very securely.
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
[Re: AndyF]
#1491467
08/27/13 02:59 PM
08/27/13 02:59 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
For about $5 in materials, I made this:
